TNT Racewerks
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > Regional Forums > Canada > Corner Balancing and Alignment
      08-03-2008, 04:49 PM   #1
J2d
Drives: none
Hey guys that are dropped on springs, coils, did you do corner balancing and is it worth doing if I don't track?
Where's a good place to do an alignment, i'm assuming must of you guys that did do a drop did an alignment as well, any recomendations?
      08-03-2008, 07:25 PM   #2
jeho
ig: jeffersonho
jeho's Avatar
Finland
148
Drives: E90M3.E36M3
no..it is not worth it if u dont track your car and i assume if u do, you would be a novice?
Just do alignment!!
Dales Alignment does excellent work for my e92 & e90 and 3 of my frds with STI which we all track
E36 M3 on TE37SL
E90 M3 on TE37SL
http://instagram.com/jeffersonho
      08-03-2008, 08:21 PM   #3
323d
323d's Avatar
Hong Kong
52
Drives: 335i E90
where abouts in Canada are you from?
Dales is good, so is Advance in Richmond.. usually it will cost you 100-120$ for allignment
ZSP susp//18's 550i reps//blacklines/aftermarket grill//
      08-03-2008, 10:15 PM   #4
jeho
ig: jeffersonho
jeho's Avatar
Finland
148
Drives: E90M3.E36M3
dales charges 90 bucks...
Ask for Jason... He gives you the setup that fits you most if you need any adjustments,
or questions regarding how your car is handling @ track or autox, he will re-adjust accordingly and also give u a fair bit of knowledge for those who arent that familiar with suspension tuning...
IMO better than many of the alignment shops that just AUTOMATICALLY give you OEM spec settings, even though majority will want that, this way incase you do spirited driving and want something a little more than OEM, it will save u the trip from going back too soon
E36 M3 on TE37SL
E90 M3 on TE37SL
      08-05-2008, 08:46 AM   #5
J.
J.'s Avatar
Hong Kong
28
Drives: E90 320i, E36 M3
2007 335i  [0.00]
Corner weight balancing is not. Some people who do not like their car to look like all 4 corners are dropped unevenly should not even think about a corner weight balance at all! Mainly to balance the weight for the car they use the height of the vehicle to distribute the weight.
If sitted a passenger or 2 in the car it will also upset the inital corner weight balance..
Jon
