04-27-2019, 09:38 AM | #1 |
Respect My Authoritah
368
Rep 873
Hey all,
I've had BM3 for a few months now, but have never explored logging. I'm running the Stage 1 93 Octane map, and am considering going to Stage 2 after installing a downpipe. I'm not really sure what I'm looking at. Can someone tell me if there are any problems? I don't want to go to Stage 2 until I find out it's running well. I did a couple pulls in 3rd gear starting from around 2500-3000rpm. This is what BM3 recommended on their site when logging. I did one in 4th gear too. Timing seems to be off later in the RPM band. Why is that and how can I fix this? What is the "Knock Detected 0/1" line? Thanks in advance! 3rd gear http://www.bootmod3.net/log?id=5cc463adc090c6741b838858 http://www.bootmod3.net/log?id=5cc463adc090c6741b838859 4th gear http://www.bootmod3.net/log?id=5cc463adc090c6741b838859
2014 335xi M-Sport 6MT: Estoril Blue II, MHD Stage 2+ , Dinan Exhaust, Dinan CAI, ER Catted DP, ER Chargepipe, AA FMIC.
04-27-2019, 01:40 PM | #2 | |
dad bod
389
Rep 382
Knock detected is exactly what it sounds like -- if the DME detects knock it will show up as a value of 1. Don't worry about it unless it appears!
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
04-27-2019, 01:52 PM | #3 | ||
68
Rep 241
Korvo368.00 |
04-29-2019, 09:31 PM | #4 |
368
Rep 873
Thanks for the comments! I live in MN and use Shell's 93. I'm still on stock plugs, which have 53k on them. Sounds like replacing these wouldn't be a terrible idea?
04-30-2019, 10:28 AM | #6 |
368
Rep 873
I didn't tune it until 45k, but I hear you. I've read a lot about properly gapped NGK's if going to stage 2. Will have to do this soon!
05-02-2019, 10:26 PM | #8 |
368
Rep 873
Does anyone know what timing values, or differences between cylinders would be concerning?
05-07-2019, 08:49 PM | #9 |
BimmerPost Supporting Vendor
24297
Rep 190,975
Send your logs to PTF
05-07-2019, 10:02 PM | #10 |
1084
Rep 2,361
+1 to what "outofphase" said.
The knock sensor is a finely calibrated microphone that listen to the engine. Before actual detonation/knock there is a sliding scale of sounds the DME can react to which is what you see when timing is retarded ~3 degrees in your log. All in all though, those retards is an indication of the engine being on the limit of what it can do with the octane available. What is seen is nothing to be alarmed about but as said before, you can go down to a lesser octane map or bump the octane to have the engine run with a bit more safety margin.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) Last edited by harkes; 05-07-2019 at 10:07 PM.. |
Korvo368.00 |
05-08-2019, 07:33 AM | #11 | |
368
Rep 873
05-08-2019, 08:29 AM | #12 |
305
Rep 526
The question I have is why's it detecting knocking when he has 93 oct map while using 93 oct? What's the point of even having a 93 oct map if the 93 oct gas isn't gonna hold up? Asking because I plan to go from stock to stage 2 93 soon and all I use here is 93 gas
05-08-2019, 09:09 AM | #13 | |
1084
Rep 2,361
(A Dane in China) |
05-08-2019, 10:12 AM | #14 | |
368
Rep 873
05-08-2019, 10:14 AM | #15 | ||
305
Rep 526
05-08-2019, 11:11 AM | #16 |
54
Rep 222
I think the problem is in the USA and Canada you guys have shit fuel which is often labeled as 93 but is in fact not on par with the quality its supposed to have. Just my observation/experience.
Another problem i see is people are obsessed with power gains which makes tuners go for OTS maps that are too aggressive for being OTS maps maybe? like why would you want the most aggressive and not the most safest for ots? i would.. but i guess most ppl just want gains.. with so many ppl needing to add additives to their fuel to have smooth timing etc, i think the best for most people would be to go for 91 map and tank 93 gas.. thats generalizing it a lot of course and everyone can do their own logging with the fuel thats available and act accordingly.. its just a conclusion iv come to by reading these forums daily |
05-08-2019, 12:05 PM | #17 | |
368
Rep 873
05-25-2019, 07:44 AM | #18 | ||
68
Rep 241
Korvo368.00 |
05-25-2019, 02:27 PM | #19 | |
dad bod
389
Rep 382
I think maps are also getting more aggressive just because ECUs are getting a lot smarter. I remember the OTS maps available for my 04 WRX back in the day being super conservative. I have a feeling that most computers are so quick to adjust timing and throttle angle and calculate load that it's significantly safer to push these cars because it's like having a nanny
JuiceQuadre54.00 |
08-12-2020, 10:21 AM | #20 |
38
Rep 12
Would anyone be able to review this 3rd gear log and tell me if it looks alright? 3rd gear pull had to slow down right at the end for a cop.
https://www.bootmod3.net/log?id=5f34...90c67b4502decc
F32 435XI- Apex Arc-8, KW V2, VRSF CP/FMIC/DP, GFB DV+, 335is/550i clutch kit, N20 TMAP, 22psi custom tune
08-12-2020, 04:37 PM | #21 | |
4367
Rep 7,613
Insane435480.50 |
08-18-2020, 06:34 PM | #22 | |
481
Rep 1,468
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
