Aftermarket rim strength?
04-25-2019, 02:08 PM | #1 |
21
Rep 62
Thanks to the crappy Toronto road condition I got my tire and rim wasted, while I need to replace 3 tires and 1 rims, it痴 just better to sell it and go to 18s or even 17s.
Maybe everyone already know this but I just would like to share that 19 summers ride BETTER than run-flat 17s. I wonder how strong the aftermarket is compare to OEM? Of course I知 talking about brand name, high quality aftermarket rims here, and preferably lightweight as well. I知 not sure this is true or not, but some tells me that forged BBS are not as strong as OEM rims because OEM rims have to take a lot of abuse. Well, as you see I did bend OEM 19 rims (style 225M), but only slightly, and the pothole is huge, so I have no clue if the OEM is really that strong, many people are comparing OEM vs cheap replicas and in that case of course the OEM is stronger. I値l go with a staggered setup, front 225-235, rear 255 (current 265 is rubbing on the inside), it just handles much better. My choices are limited to OEM staggered 18 (no staggered 17 I believe), aftermarket 18 or 17, if it clears 335i brakes, lightweight seems better but my big concern is the strength. Thanks in advance. |
04-26-2019, 04:07 PM | #2 |
BimmerPost Supporting Vendor
3530
Rep 6,752
This is a great question. Many assume OEM wheels are the end-all be-all of quality and strength. While OEM wheel quality is very consistent, they are always susceptible to bending if they take a hard enough impact in the right spot, regardless of manufacturing process (cast, flow-formed, forged, etc).
The best thing you can do is be an informed buyer. Do research on any aftermarket wheel company you're considering. Ask what certifications their wheels have, such as VIA, TワV, etc, and ask them to prove it by showing their certificates or registration numbers. Look into load ratings as well, as these are the prime indicator of a wheel's strength. Lastly, diameter makes a big difference since it directly effects how much cushion (tire sidewall) is between your wheels and the road. 19" wheels have very little protection while 17s will have much more. Hope this helps! --Dylan
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
04-28-2019, 02:08 AM | #3 |
57
Rep 59
Bent 19" Niche
Most aftermarket wheels are softer unless they are an expenses mono-block, I installed 19" Niche wheels and hit only a small pothole once and bent the wheel, I didn't lose air pressure but had to replace it.
Instagram@stephanporsche
Porsche 996 Turbo Porsche 997 Carrera S BMW E90 328i LCI |
04-29-2019, 08:46 AM | #4 | |
70
Rep 491
I had 18" style 193M wheels and bent 3. I switched to 18" apex ARC8 and they haven't bent. I actually swerved to avoid an accident a few months ago and had to hop a curb and (knock on wood) i dont think they even bent doing that. Look for companies that are going to light/strength as much as style.
2011 N55 e92 Msport -Alpine White AT MHD Stage 2+, ARM 5" stepped I/C, PPK (coded over), Cobb charge pipe, gutted Xi downpipe, BMS intake, ARM I/C hose upgrade, PE mod, ST coilovers, 18x9 Apex ARC8 |
maxnix205.00 |
04-29-2019, 10:13 AM | #5 |
1209
Rep 2,476
It's really hot or miss. Not all OEM wheels are super strong or weak. Same for "brand name" aftermarket. You pretty much have to research and see which brand/model tends to be better/worse. For instance, style 296 on the Z4s have been terrible and there's a class action settlement against BMW because of them. At the same time, style 513M and 437M are forged and known to be light and strong. Generally speaking, cast wheels tend to be heavy and weak, forged light and strong, and flow forged(there's other descriptions of the same process) lie somewhere in between.
04-29-2019, 10:25 AM | #6 |
140
Rep 476
Toronto streets eat wheels! My brother inlaw broke 3 different 19" wheels (different brands) over 3 years on his e93. I can't tell you through brands though and I'm sure this plays a factor. His girlfriend broke a 17" oem wheel on her Mini. He now runs Apex arc 8 in 19" wrapped in Indy 500 and so far (2 summers) hasn't dented or broken one.
05-04-2019, 01:55 AM | #7 | |
21
Rep 62
I think I just bought your brothers 19" rims😂 I want the tire only but he had them on the tire, so this morning I bring them to Costco to swap them to my style 225M. I realized it was hard to source used 18 rims anyways so I would keep my 19 set for now as it would be cheaper and less work to do. Still in the process of claim, but I will sue the city if they deny it. New wheels is $917 CAD each I can't just stand to let it go like this! |
05-04-2019, 01:56 AM | #8 | |
21
Rep 62
