04-23-2019, 01:43 PM | #1 |
211
Rep 274
Wireless Charge Pad Overheating iPhone X
I have a brand new M340i and my wireless charge pad yesterday overheated my iPhone. I actually got the same overheating message you get when you leave the phone in the sun. Anyone else have this happen? I had no case on the phone.
04-23-2019, 02:04 PM | #4 |
Ring Leader of G8X Haters
25076
Rep 8,762
Seems to be an issue on not just the 3 series, I've seen similar posts on the 5, X5, and X7 forums, I would avoid using it, I remember one guy on the X5 forums said his phone overheated so bad he had to replace it
Current Garage: 2022 Mercedes-Benz S 580 / 2023 Genesis GV70 2.5T / 2007 Mercedes-Benz E 350 / 1999 Mazda MX-5 Miata
Retired: '95 E36 325i 5MT / '04 E46 330i 6MT / '05 E83 X3 3.0i / '11 E90 335xi / '17 G30 540i / '19 F87 M2C 6MT / '19 MB CLS 53 / '20 MB GLC 300 |
04-23-2019, 02:31 PM | #5 |
218
Rep 500
Do you use a wireless charger at home?
04-23-2019, 02:34 PM | #6 | |
211
Rep 274
04-23-2019, 03:09 PM | #7 |
1996
Rep 2,499
Are you using Carplay while the phone is charging? Wireless charging can make phones a little warmer than wired charging and using something like CarPlay will also increase the phone's temperature. Typically when you charge at home, you're not using the phone so it can charge without issues.
Also, make sure you are centered on the charging pad. I believe iPhone charging coils are centered on the phone as are the coils in the charging tray in the car. |
04-23-2019, 03:10 PM | #8 | |
211
Rep 274
04-23-2019, 03:18 PM | #9 |
309
Rep 572
Mine gets a little warm but doesn’t overheat. This is on a 45 minute trip. And phone is in a case.
I have noticed sometimes the phone’s screen is on and then it’s hotter. Was your screen on ? I also leave the cover open. |
04-23-2019, 03:57 PM | #11 |
211
Rep 274
04-23-2019, 06:46 PM | #13 |
211
Rep 274
04-23-2019, 10:50 PM | #14 |
Rep 43
I don't have wireless charging (6NW) but when I lay my iPhone on the pad, the NFC automatically brings up Apple Pay Wallet (and it never closes) and the phone does heat up, although not to the point of overheating. Not sure why this is happening on a consistent basis or what the impact is on my battery but it is disconcerting and not apparently related to charging.
04-25-2019, 08:19 AM | #15 |
70
Rep 223
I tried it yesterday. Charging itself doesn't heat it up. But using carplay does. Also, carplay drains more power than the wireless pad can deliver
iPhone Xs
Grz D.!
04-29-2019, 03:59 PM | #16 |
211
Rep 274
Ok so the latest on this...when using CarPlay and Apple Maps navigaton the phone overheats wether it is in the wireless charging tray or not. This seem to be pointing the overheating to the CarPlay side of the house.
The other thing that is happening is that half way through my phone calls the call audio begins to lag. The person on the other end hears me a few seconds after i complete my sentence. In addition to all that i have intermittent connectivity and streaming issues with Pandora Radio through CarPlay. Seems like the phone wants to use the cars wifi network then realizes it needs to use LTE instead. Lots of quirks I must say...I think an update is needed but not sure if its from Apple or BMW or if we have a hardware/software incompatibility issue. Not to happy right now... |
04-29-2019, 04:03 PM | #17 | |
25076
Rep 8,762
vicfalc09211.00 |
04-29-2019, 04:16 PM | #18 |
211
Rep 274
11-08-2019, 03:06 PM | #19 |
120
Rep 129
Brough my m340i in today for some warranty work and asked about the overheating issue. Was given this SIB bulletin as their answer. Basically we need to center the phone and minimize use when wirelessly charging. Seems like a complete waste of equipment if you can't fully utilize the phone while it's wirelessly charging. Going to start using the USB-C charging port in the center console.
Has anyone noticed improved connectivity, fewer crashes and less overheating when using the USB-C charger instead of the wireless charger? I kinda want my $500 bucks back. |
11-09-2019, 12:25 PM | #21 |
Part of the bimmer family!
139
Rep 293
Drives: BMWG20; BMW E90
'Seems legit' though... I also find my Apple Watch to be quit warm when I take it of my wireless charging cradle.
“You can put wings on a pig, but that doesn't make it an eagle.”
11-09-2019, 01:13 PM | #22 |
120
Rep 129
This is my daily. Pandora...Waze....maybe a phone call with obvious delay...throw in a text message and forget about it. Crash city.....
