04-23-2019, 12:38 PM | #1 |
32
Rep 64
2017 6MT Fill and Drain Plugs
I would like change the fluid in my 2017 manual transmission and I have read it is recommended to change out the drain and fill plugs along with the associated washers. I have spend a considerable time searching for the part numbers and a place (short of the dealer who wants $26 for EACH plug) to source these with no luck.
Any assistance would be appreciated! |
04-23-2019, 12:47 PM | #2 |
844
Rep 1,962
RealOEM doesn't appear to list the plugs as separate items, and New TIS just says undo them and retorque. So maybe just reuse.
Why do you want to change as a matter of interest? |
04-23-2019, 06:55 PM | #4 |
1717
Rep 1,899
Don't see how plugs would be replaced since they're not torque to yield on a structural part such as the large bolts that hold the belly pan on the front underside of the car
04-24-2019, 05:12 AM | #5 | |
32
Rep 64
I purchased the car used and do not want to pay to transfer the dealer provided maintenance to my name. I like to do my own maintenance anyway and I am not satisfied with the few records available on past service. Regardless of what the cars computer says for maintenance intervals I want to start a baseline where I know services were done. As long as I keep records and receipts I should be good from a warranty perspective. |
04-24-2019, 05:14 AM | #6 |
32
Rep 64
I read the same replacement recommendation for the differential drain and fill as well. I have never replaced the plugs on any previous car, just the washers which I think I will stick with.
04-24-2019, 06:49 AM | #7 | |
844
Rep 1,962
Unless someone has already been in it, the MT currently has FFL fluid in it though, so it shouldn't need changing for some years. HTH. |
04-24-2019, 06:57 AM | #8 | |
32
Rep 64
I need to do some more searching but I thought the manual transmission oil on M cars is supposed to be changed at 1200 miles. |
04-24-2019, 08:22 AM | #9 | ||
1717
Rep 1,899
Like the others have said the MT fluid is considered a lifetime fluid so whether or not you want to change is totally up to you. |
AndrewC198910932.50 |
04-24-2019, 09:28 AM | #10 | |
32
Rep 64
04-25-2019, 03:11 PM | #11 |
1860
Rep 2,104
Historically, BMW has not considered 6MT fluid lifetime. All M's had a 6MT fluid change as part of the 1200 mile break-in until until the F80/82 I believe. It was in the car's instruction/maintenance manual. But this is when BMW had a more comprehensive, and longer, free maintenance program. If you plan to keep the car a while, I'd do the flush. Personally, I see it as BMW cutting corners because it won't be their problem down the road. I'm planning to have the dealer flush my 6MT fluid at my 1200 mile break-in. It's not that expensive, and I'm happy to pay for it.
04-26-2019, 03:02 AM | #12 |
844
Rep 1,962
The 6MT in the E46 from 2002 had lifetime fill (and a sticker on the casing that says the same) - MTF LT-2. Possibly the local dealerships change this stuff to meet customer expectations in NA.
