Springs with Stock Shocks
08-02-2008, 12:56 AM | #1 |
13
Rep 483
I'm thinking about just putting on H&R springs and keeping my stock shocks. How does the ride feel with this set up?
08-02-2008, 01:06 AM | #2 |
228
Rep 3,807
Drives: Retired 2017 F87 M2
I have that setup currently. The ride is pretty good, however you can really feel it when u hit a pot hole, but that is the price u pay for a lowered ride i guess..
2017 M2 Coupe:|Black Sapphire Metallic|DCT|Nav/Idrive|M Performance CF Spoiler|M Performance CF DCT Interior| M Performance Gloss Black Kidney Grills| M Performance Steel Pedals | Eventuri CF CAI | 19" Brixton Rims | KW V3 Clubsport |
Retired: |2008 328i Sedan|Montego Blue| |
08-02-2008, 11:04 AM | #3 |
98
Rep 3,618
What about rebound control? Does the car tend to wallow before settling when you drive over smooth bumps or dips in the road?
2016 Mercedes-AMG CLA45
2013 Mercedes-Benz B250 - Gone 2010 Mercedes-Benz C350 4Matic - Gone 2006 BMW 330xi - Gone 2001 Infiniti QX4 - Gone |
08-20-2008, 02:02 AM | #4 |
Loading...
341
Rep 2,187
Drives: 91' E30 318is
I would like some insight on this too since I'm planning to do the exact same thing. I have a 328xi with OEM sport suspension, if I get the H&R springs would I have better handling? Sorry about the
08-20-2008, 02:03 AM | #5 |
228
Rep 3,807
wat do u exactly mean by wallow before settling? Like bounce, after smooth bumps?
08-20-2008, 02:09 AM | #6 | |
228
Rep 3,807
The only difference when you lower your car is that, when u hit pot holes, u really feel them. But, that is the price u pay for lowering ur suspension.
08-20-2008, 02:29 AM | #7 |
135
Rep 1,825
after reading a ton on this same issue, your ride will slowly go to crap because the stock shocks arent made for the springs. Just do it right and match your shocks and springs.
08-20-2008, 02:31 AM | #8 |
228
Rep 3,807
the other alternative is to get Koni yellows + H&R sport springs.
08-20-2008, 06:17 PM | #9 |
663
Rep 26,878
Drives: 2-325 330 2-335 2-Z4 2-135 X5d
Is there any Coilover vs springs thread?
I've been looking but can find one. . . I want to see the benefit of getting the coilovers and paying $1,500+ when you can get springs for like $200+ I always thought that you really only needed coilovers for tracking your can so it was planted better at launch |
08-20-2008, 06:23 PM | #10 |
228
Rep 3,807
first and for most, coilovers is the best bang for the buck, if money isn't an issue. It gives you more flexibility, cause u can freely raise your cars height when needed. It gives u better handling and its stiffer than if you just got springs.
And yes coilovers are a must when u track. Which is y people prefer to get springs and shocks instead. Cause its really not worth the money if ur just using ur car for daily driving. But, yea it all depends wat u want.
08-20-2008, 08:20 PM | #11 |
57
Rep 615
Where can I find Koni yellows for an xi car? Do they even make them for xi?
'06 330Xi, '04 CBR600RR, '04 YZF-R1, '06CBR600RR, '10 S1000RR M-tech, Injen, Hamann, Remus, KW, Breyton |
08-20-2008, 08:28 PM | #12 | |
189
Rep 2,502
As for using aftermarket springs with stock shocks, it's been done before and it continues to be done. In my opinion, a spring like the H&R spring which lowers the Xi coupe 1.3" in the front and 1.2" in the rear is fine for the stock shocks. Unless you track your car or drive it like you stole it every day, there is no need to upgrade shocks. With that said, I personally would not run a car with aftermarket springs without aftermarket shocks. That's my opinion though. I figure if I'm going to swap out suspension, I might as well replace everything. I have lots of customers just running aftermarket springs with no problems. |
08-20-2008, 08:37 PM | #13 | |
81
Rep 849
I recomend against this combo. I'm getting the KW V3's soon.
08 E92 335xi Space Gray 6AT - PROcede V2 12.8 @ 111 mph
08-20-2008, 11:19 PM | #14 | |
Rep 72
Drives: 2013 535i
2010 335i Cv | Le Mans Blue | Black/Gray Poplar AT | M Sport | ZPP | ZCW | NAV | Logic7 | CA | PDC |
08-23-2008, 03:24 AM | #15 | |
Loading...
341
Rep 2,187
So after that I'm going to have to say no and save up for some shocks and springs set, as I drive the car like I stole it . Thought I don't mind pot holes as the run-flats can't take the potholes already. Thanks for your help everyone! |
08-23-2008, 07:31 PM | #16 |
49
Rep 248
i had H&R Sport spings on stock shocks on my last car.
i thought i was getting a nice drop cheap, but after installation and alignments i needed a camber kit. so the springs were $200, the install was $200 the 1st time and$150 to redo the rear. the rear camber kit was around $130, alignments were $70 each and a half hour ride for a Hunter with a lift. and i wanted it lower/ stiffer/ adjustable. i was about to upgrade to coilovers before i upgraded to BMW. just do it right the 1st time im thinking of going for H&R coilovers |
09-01-2008, 03:02 PM | #17 |
152
Rep 2,459
i have had this setup on my e92 xi for 6 mos+ and here are the positives/negatives
Positives 1. Turning is alot better, nowhere near as much body roll in turns (you can turn at a faster speed vs stock) 2. Car looks a hell of a lot better, no more 4x4 Negatives 1. Car is slightly bouncy, esp. at high speeds if you hit a dip Now the obvious 1. Car is lower which means your more likely to scrape/bottom out etc 2. Car already felt like shiet when it hit potholes with the OEM suspension, but lowering the car on H&R's seems to make you 'feel' the potholes alot more |
09-01-2008, 03:11 PM | #18 |
313
Rep 2,576
Simply lowering your car does not always give you better handling as stated above. Lowering the car too much can completely screw with the suspension geometry creating worse handling. Coilovers or springs and shocks that are designed to work together are your best bet. I would think lowering springs on stock shocks will more than likely decrease the handling capabilities of the car.
09-02-2008, 08:25 PM | #19 |
152
Rep 2,459
^^thats what you would expect, but its very obvious how much easier it is to turn at a high rate of speed w/ the lowering springs vs stock. The floaty feel is completely gone with the springs, but the bouciness increases
09-02-2008, 09:00 PM | #20 |
631
Rep 24,685
Drives: '04 330i ZHP
god i know your pain... madison AND chicago are just constant "THUDS" that feel like I am hitting so hard I might see my transmission in my rearview sooner or later.
09-02-2008, 09:24 PM | #21 |
674
Rep 4,080
Urrgh, the misinfo out there
First, this stuff about how a lowered car improves handling is only part of the story. Simply lowering your car with springs will probably degrade your overall performance. See, the true handling characteristics of a car are not realized in simple street driving, how it handles pot-holes, etc. It's found on the track with the car pushed to the limits. Under-steer, over-steer, roll, recovery, transfer, brake bias, etc. is all a function of a tuned suspension. The 335 suspension is tuned for the 335, including run flats, driver profile, and target market (luxury vs. sport). Throwing a mismatched component into a tuned system and expecting an automatic improvement in handling is simply unrealistic. This is why Coil Overs tend to work so well. They are a matched (read tuned) upgrade and when from a reputable source (like KW) the combo's are also matched to a car profile. The problem is that for you to get all you can out of them you have to be willing to fine tune them. If spending the time fine-tuning a CO set up does not sound realistic to you (like 90% of the people here have them but don't) then you can also go with a matched spring/strut combo and save a few $$. Koni Yellows are great because they let you adjust dampening rate (like K2's). Only thing is you will not be able to adjust height or corner balance like with COs', but usually only the hardcore bother to do that anyway. Also, do not underestimate how much a new set of sway bars can help improve handling on our overweight pigs. I'd spend a little time and get in touch with some of the reputable vendors here mapping out different options, if you are interested in improving the handling of your car. Otherwise just drop your car for looks, becasue that's basically all a new set of springs will do for you. |
09-02-2008, 11:56 PM | #22 |
313
Rep 2,576
Magna3 is right on. While you may feel like the car is handling better, the reality is it is not. Lowering springs rarely if ever improve the cornering capablility of the car. The only benefit you have achieved with the lowering springs is a lowered appearance.
