04-20-2019, 02:15 PM | #1 |
29
Rep 94
Bluetooth streaming audio constantly dropping
This is driving me insane. not using CarPlay - just standard bluetooth streaming from my phone (iPhone XS, iOS 12.2), using spotify.
every 5 - 10 min it drops for 3 or 4 seconds, then reconnects. somtimes more often, sometimes less often. always aggravating. i've never exprienced anything like it on any device ever (speaker, headphones, car, etc). what gives? if i look on the phone bluetooth settings, it doesn't reflect the disconnect. only on the car. version 3/2019.35, April build. |
04-20-2019, 02:34 PM | #2 | |
208
Rep 279
Drives: 2023 BMW X5 M Competition
04-20-2019, 02:36 PM | #3 |
29
Rep 94
04-20-2019, 02:39 PM | #4 |
208
Rep 279
i don't use carplay. I was just talking bout the messages from standard bluetooth connection.
04-20-2019, 10:44 PM | #5 |
30
Rep 78
I've had the same issue a few times. I've tried unpairing and pairing again with no help. What I've found works is when there is an issue with the connection, turning my iPhone off and on again fixes it. No idea why, but it's worked successfully each time the problem rears it's ugly head.
04-20-2019, 10:53 PM | #6 | |
80
Rep 204
05-05-2019, 01:30 AM | #8 |
Rep 1
I had the same issue with iPhone XS Max before as well. It works perfectly fine with bluetooth connection after I disable the CarPlay function, which I actually don't use that at all. Hope this solution can help you all.
05-11-2019, 02:03 PM | #9 |
Rep 7
Hello all,
I recently tried a reset of my network settings on my iPhone 7 Plus and I've not had issues ever since. Bluetooth audio connects right away every time and stays on. It's worth a shot if you're still experiencing disconnects. Go to Settings > General > Reset > Reset Network Settings Post your results. |
05-11-2019, 02:50 PM | #10 |
29
Rep 94
this goes away for me after i reboot my phone. sometimes that will keep it away for almost a week, sometimes almost 2. def seems like there's something between ios and idrive that isn't quite right. rebooting phone helps, rebooting idrive doesn't, so probably ios's fault.
07-06-2019, 06:43 AM | #12 | |
15
Rep 30
