BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum Dash Cam Installation
      04-16-2019, 02:06 PM   #1
Scanger
Drives: BMW X7
Hi Everyone,
Just wanted to see if anyone has installed a dash cam for their new X7 yet.
I would like to install one but am not sure how to do a clean install. I am also not sure if hard wiring a dash cam will void the warranty on the car.
I would appreciate some feedback on this subject.
Thank you!
      04-16-2019, 04:35 PM   #2
masmole
266
Drives: blue, gray, brown cars
In our recent cars (Audis, Land Rover) a clean install was made very easy by a simple mirrortap solution that you could order from places like amazon. For those that don’t know, mirrortap is a short-run cable with a power connection at one end for various 12-volt radar and dashcam applications and on the other end a couple of small spade terminations for “tapping” into the existing wiring harness connector on the overhead console (where the sunroof, telematics, and overhead lighting controls are). The mirrortap packages have an inline fuse built-in for safety and for low-power applications like radar detectors and dashcams, they are perfect. The only bit of knowledge needed is where the ground and accessory-power slots are in your specific car’s harness and of course how to safely remove the overhead console cover to get to it.
For my last 3 Audis and current Range Rover Velar, this was shockingly similar and easy to do. I currently have Blackvue dashcams installed via mirrortap on all my cars, and have made detailed DIY posts with pictures on both the Audi and Range Rover forums for all the cars I’ve done it on. I suspect any BMW will be just as easy, though I don’t have an X7 yet to try doing it to. Once I do, I will surely post a DIY here as well, but I suspect someone will beat me to it since I don’t expect an X7 until fall at the earliest.
2021 A6 Allroad, 2020 SQ7, 2019 M5 Comp, 2011 GT3
past: A4, S4, X5 4.8is, SLK55, E60 M5, RS4, ML63, E92 M3, Q5, Touareg TDI, Escalade, SQ5, RS7, Velar FE, Q7
Appreciate 3
Wild Blue3683.50
JDBrown62.50
edikam6.00
      04-17-2019, 08:29 AM   #3
Scanger
Drives: BMW X7
That's very helpful! Thank you so much.
      04-18-2019, 12:04 AM   #4
kbl888888
30
Drives: 2019 BMW X7 50i
BlackVue DR900S + BlendMount BBV-2018
jokinawa293.00
      04-18-2019, 08:14 AM   #5
Scanger
Drives: BMW X7
Originally Posted by kbl888888 View Post
Wow, nice set up. Do you mind me asking if the mirror tap set comes with the camera or do I need to buy it separately? Where can I get this set up?
Thanks!
      04-18-2019, 06:53 PM   #6
kbl888888
30
Thanks!
Hi, I bought this on this website
https://www.blendmount.com/index.html
      04-18-2019, 08:29 PM   #7
Jmrdmd
Drives: 2019 X7 50i
Looks awesome. Could you show where you connected the mirror tap?
Thanks
Jan
2024 911 ST (May 2024)
2024 Audi RS6 Avant Bronze Edition
2020 M8 Cab
1996 911 Targa
      05-18-2019, 10:19 PM   #8
jokinawa
293
Drives: 2019 X7 40i
Does the mirror tap allow you to use parking mode?
      05-19-2019, 12:13 AM   #9
jmciver
///M SubDriver
jmciver's Avatar
1836
Drives: 2017 M3, 2020 X7 40i
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
2009 BMW 128i  [0.00]
Most likely not. I have a BlackVue dash cam installed in my F80 and in order to use parking mode you either need a battery backup (preferred & recommended) or a Power Magic Pro hardwiring kit (not recommended). I am assuming that the mirror tap taps into a power supply that will turn off at some point after the ignition is turned off. If it is attached to a constant power source, the camera will not turn off (even though it will shift to parking mode), and the battery would be drained and cause other types of electrical gremlins to show up.
I use a battery backup for my dash cam and is the recommended way to go in modern BMWs with their very intricate electrical systems. IMO, the best way to power a dash cam system is to tap directly to a switched fuse in the fuse box using a battery backup system. I wired mine using an unused, switched 12V fuse spot in the rear fuse box on my F80.
///M3 COMPETITION 6MT - 2017 F80 Smoked Topaz Metallic
BM3 / MP-HAS / GC Camber Plates / Carbonstructure Interior
X7 XDrive 40i ///M-SPORT - 2020 G07 Arctic Grey Metallic
X3 XDrive 30i - 2019 G01 Mineral White (wife's) / 128i 6MT - 2009 E82 Jet Black (son's)
      05-19-2019, 06:39 AM   #10
jokinawa
293
Drives: 2019 X7 40i
Thank you for the helpful answer.
If my post was informative or helpful, please click the appreciate button. Thank you.
      05-19-2019, 09:29 AM   #11
jmciver
///M SubDriver
jmciver's Avatar
1836
2017 BMW M3  [10.00]
2020 BMW X7  [0.00]
2019 BMW X3  [0.00]
No problem Below is a thread I posted where I documented my F80 dash cam install. Inside that thread is a link to the other thread I made about how to tap into the fuse box using factory wiring inserts.
https://f30.bimmerpost.com/forums/sh....php?t=1575590
Obviously not the X7, but the basic process of how to run the wiring and taking apart interior tim pieces is the same. Also, since the BMW repair procedures are available online, all of the correct resources are available to do a quality job (I used those same procedures to do my dash cam install).
Admittedly, I have not decided if I want to install an aftermarket cam in an X7 as I usually prefer leaving things looking OEM in the cabin. The new factory camera features coming to the X5/X7 may even allow the factory cameras to perform more like an aftermarket dash cam, which would be preferred for me if the functionality is up to par. Only time will tell I guess.
xbimmers
