04-16-2019, 01:09 PM | #1 |
Rep 7
Engine Braking in a Modern Automatic - Good or Bad?
Hi all,
I recently purchased a relatively new BMW 3 Series with the M Sport pack which includes the paddle shifters and whatnot. Having switched from a manual car, I'm wondering if engine braking is particularly bad for the transmission in a car that can be in automatic mode OR manual mode, as I don't know the ins and outs of whats going on under the bonnet. I always used to downshift to about 3000rpm continuously to slow down when seeing a red light ahead for example (as well as using the brakes lightly of course). Is this a good idea in my new car? Many thanks! |
04-16-2019, 01:13 PM | #2 |
2466
Rep 5,457
Drives: F30
Even though I do not downshift my auto box to slow down... Im interested to hear the answer to this question...
04-16-2019, 01:20 PM | #4 |
dad bod
389
Rep 382
I don't know a ton about the ZF transmission but my guess is you should be fine. The wear from the downshift should be relatively similar as that of an upshift. If anything I'd guess there'd be LESS load on the clutches during deceleration than when accelerating.
Hopefully someone with more knowledge can chime in.
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
04-16-2019, 01:39 PM | #5 |
133
Rep 433
I've used engine braking only rarely, mainly when descending a steep slope in Colorado, New Mexico, or Texas (yes, Texas has some steep pitches). I thought that was the main use for it.
Lance_Goodthrust4.50 |
04-16-2019, 02:31 PM | #6 |
Curmudgeon and Pedant
690
Rep 3,489
Given that recent ZF transmissions rev-match downshifts, I wouldn't expect any problems. My older e90 335d with the ZF6HP26 at 135K shows no problems attributable to clutch wear. Lots of people run in sport mode, which is fairly aggressive in it's use of downshifts, and no one seems to have complained of wear problems.
bimmer4562982.50 |
04-16-2019, 02:41 PM | #7 |
Cheapskate
4450
Rep 4,995
It's not going to cause the trans to fail prematurely if that's what you're worried about. Keep in mind that the car engine brakes no matter what when you're slowing down in gear. It's the most efficient way to slow down.
All the manual mode does is force the actuators to move when you tell it too. It's not really different from other automatics. |
04-16-2019, 02:42 PM | #8 |
1599
Rep 3,748
Go drive on sport or sport + mode on auto then just decelerate and you will know the car use engine braking when the transmission downshifts by itself. So I don't think there is harm on this. Unless your okay driving on comfort or eco pro😂
sea_m2c82.00 |
04-16-2019, 06:37 PM | #9 |
731
Rep 1,045
Engine breaking is absolutely fine, like mentioned above, both in sport+ and ecopro, the car downshifts because sport+ keeps your rev up for power readiness and ecopro downshifts to save fuel. You'll notice this much more when you're going down hill and touch the brake, the car will downshift everytime. ZF8 is built for it, there's no damage done whatsoever. The shift is smooth too, if you feel a jolt then your transmission may have issues.
04-16-2019, 06:44 PM | #10 |
Rep 20
I drive exclusively in Sport DS (shifter to the left), and the engine 'brakes' all the time through slightly aggressive downshifts. I have had the car for about a year (f30 328) and have had no tranny problems.
04-16-2019, 10:31 PM | #11 | |
809
Rep 1,597
04-16-2019, 10:34 PM | #12 |
10835
Rep 3,715
Engine braking is what men do.
Realistically though, you're wearing out parts every degree your tire rotates, every stroke, every shift. Some argue that gearing and components of your drivetrain take a little more wear (insignificant and no scientific data to back it up) and that it makes more sense to wear out your replaceable pads than your drive train but there's a lot more to it than just wearing out pads. Kinetic energy converts to thermal energy which will affect more than just your pad but again, in daily driving this will be insignificant just like engine braking. That being said, I've been engine braking my whole life and never had an issue as a result of it. It also forces you to be more attentive while you drive which is never a bad thing. |
04-16-2019, 10:39 PM | #13 |
2000
Rep 2,499
The transmission solenoids/clutch packs and torque converter lockup clutch are definitely being worked out when you downshift. I'm not saying you'll ever notice slippage or wear any faster than if you didn't, but I'm just wondering what the point would be. What's the goal? To save your brakes? To sound cool while you're slowing down? If it's the former, don't bother. If it's the latter, then do it. If that theoretically did advance transmission wear, you gotta figure it only costs fractions of a penny every time you do it at most. Probably cheaper than getting an exhaust. If it's for slowing down while going downhill, then definitely downshift without hesitation.
Even in a manual, it's my opinion that downshifting at a stoplight is unnecessary. You might save a couple thousand miles worth of brake life yet use up a couple thousand miles of synchro and clutch wear. Brakes are significantly cheaper and easier to replace as well. In an automatic, where transmission rebuilds and service are much more expensive than in a manual, I just don't see the point. I stopped doing this (for the most part) in my early 20s. Just realized there was very little point. I will do it if I know I won't be coming to a complete stop like on a turn or at an imminent green light, though. |
sspade2466.00 HighlandPete6658.50 |
04-17-2019, 10:34 AM | #14 | |
6659
Rep 15,858
Also add, if drivers use engine braking to save brakes, users are likely driving pretty hard to wear brakes fast. In that case there will be extra wear on the drivetrain, using heavy engine braking, as a substitute to brakes. Users comment they don't feel there is extra wear, on what is that assessment made? 100,000+ miles use and analysis of the transmission fluid? As I see it, work the gearbox harder, (including heavy use of engine braking), the least you can do is consider a fluid change at lower mileage than lighter gearbox use. |
04-17-2019, 10:59 AM | #15 |
96
Rep 431
330d
Let the auto box do it's own thing when slowing down. Never ever thought about down shifting using the paddles for slowing in traffic, traffic lights etc! Use the brake🙄 Paddles are for fun in the twisties! |
04-17-2019, 11:19 AM | #16 |
1599
Rep 3,748
Yeah of course but this is normal wear unless you down shift and end up with RPM at 6000 for engine brake....lmao
04-17-2019, 11:27 AM | #17 |
208
Rep 245
This does not address driving around town using engine braking, but the concepts still apply (from the F30 Manual):
Hills Drive long or steep downhill gradients in the gear in which the least braking is required. Otherwise, the brake system may overheat, resulting in a reduction in the brake system efficiency. Automatic transmission: You can increase the engine's braking effect by shifting down in the manual mode of the auto‐ matic transmission. Avoid load on the brakes Avoid placing excessive load on the brake system. Light but consistent brake pressure can lead to high temperatures, brake wear and pos‐ sibly even brake failure. Do not drive in neutral Do not drive in neutral or with the engine stopped, as doing so disables engine braking. In addition, steering and brake assist is unavailable with the engine stopped. Edit: the F30 LCI manual includes: You can increase the engine's braking effect by shifting down, going all the way to first gear, if needed.
2017 F30 340i RWD // MG Flasher // xHP // CG DS-1 // ZTR ZMP ZCW ZLP
04-17-2019, 12:39 PM | #18 |
That Libertarian Guy
4039
Rep 6,363
04-17-2019, 01:01 PM | #19 |
993
Rep 1,934
Engine braking is just downshifting and then coasting. You will be fine.
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
04-17-2019, 01:44 PM | #20 | |
466
Rep 716
Plus engine breaking takes a lot longer than regular breaking, so you might save yourself a few red lights, and save wear on that side of things. |
04-17-2019, 02:00 PM | #21 | |
6659
Rep 15,858
Manual intervention.... is it really necessary? Likely more a driver's choice than necessary, as there is a lot of gear flexibility in current AT programming. Even engine braking works automatically, particularly on hills, when we prod the brake and instigate a down change or two.. |
04-17-2019, 02:01 PM | #22 | |
2000
Rep 2,499
What advantage do you think there is to sequential downshifting at every stoplight? Why wear out your synchros like that? |
