The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > 2007 e90 drl option
      04-14-2019, 01:27 PM   #1
Kilser
Kilser's Avatar
Drives: 2007 335xi
2007 e90 drl option
I was trying to follow along this tutorial
https://www.google.com/search?q=e90+...hrome&ie=UTF-8
and I noticed I dont even have the CIC module. Any guesses where and what value I need to change?
All I am trying to do is enable the option so I am able to have no DRL in Canada.
      04-15-2019, 06:53 AM   #2
erickarlborg
Sweden
15
Drives: E91 320d -08
Do you have FRM1 or 2? Different DRL codings for those
      04-24-2019, 08:53 PM   #3
Kilser
Kilser's Avatar
Drives: 2007 335xi
How would I check for that? Also I know in some other models in the US there is a option to disable them right off the I drive system. That option is obviously taken out entirely. Wondering if there is a way to enable that option possibly without disabling the lights one by one?
      04-25-2019, 02:52 AM   #4
erickarlborg
Sweden
15
Smile
In NCS you will either have FRM (FRM1) or NFRM (FRM2).
For FRM1 the options are: DRL_V_GEDIMMT and DRL_WERT_DIMMUNG (26 or 40% dimming)
For FRM2 the options are: VERHALTEN_DRL_TFL and everything else containing DRL basically
For the iDrive option it should be either CIC or CCC I think, and the option probably DAY_DRIVING_LIGHT
      04-25-2019, 10:35 AM   #5
mweisdorfer
mweisdorfer's Avatar
1903
2007 BMW E90 335i  [0.00]
2008 bmw x5  [0.00]
https://www.google.com/search?q=e90+...e&ie=UTF-8
Any car made pre 03/07 had an FRM 1. So, using angel eyes as your DRL is not an option. You need to buy a used FRM 2 on eBay for around $100.00 and then follow the various DIY's on this forum on how to use WinKFP & NCS Expert in how to code it.
The first step is to make your VO say your car is an 03/07 through NCS Expert, after you have installed an FRM 2 module.
