04-14-2019, 12:24 AM | #1 |
1579
Rep 1,479
Drives: 2022 M440xi GC
Unique to M35i parts list
I was bored tonight and did a quick scan through real oem to find the different components that the M35i has as unique (or shared with a more exotic car).
So far: Engine cover Intake airbox and filter Intake cooler lines charge air cooler Cylinder head gasket (2 unique thickness listed) Crankshaft Rear bearing shell (Crank) Shared with i8 (upper only) Piston Con-rod Con-rod bearing upper shared with i8 Exhaust valve shared with i8 Turbo injectors Transmission (hi-torque/hi efficiency aisin) Trans oil cooler Muffler Engine side exhaust cat Struts Brakes/calipers Last edited by billnchristy; 04-14-2019 at 12:51 AM.. |
07-10-2019, 12:24 PM | #3 |
1579
Rep 1,479
AWF8G45
07-12-2019, 10:21 AM | #4 |
401
Rep 1,104
07-12-2019, 12:55 PM | #5 |
1579
Rep 1,479
480nm which is scary but normal x1/2 only 350
