04-12-2019, 08:37 AM | #1 |
17
Rep 101
2nd Gear grind. maybe synchros?
If anyone has any knowledge that could help me that would be great. whenever i shift from 1st to 2nd gear from 4800 RPM to redline i get a loud grind and some friction. this grind seems to happen even if the clutch is all the way in and i shift slowly it grinds but not nearly as violent but still happens. anytime i shift below 4500 rpm it doesn't grind. i drive a 2015 m235i manual trans. about 40k miles. is there any known solution to fixing the grind? it only happens 1st to 2nd ive never had it 3rd to 2nd. thinking of trying a transmission oil change and trying redline shockproof, others have used that and had success. if anyone has any thoughts on this that could help at all that would be greatly appreciated
04-12-2019, 09:02 AM | #2 |
5565
Rep 5,378
Unfortunately the 1-2 syncros are failing and the only fix is replacing the transmission as there are no rebuild kits. Fluid won't help things. It's a somewhat common issue with any 2012+ BMW using the ZF 6MT (M cars, M235, most F series 3s and 4s).
A refurbished M235 6MT is $3,200-3,600 from BMW plus you might as well replace the dual mass flywheel and clutch while you're at it. You're likely looking at $6K USD all in. It REALLY sucks and is the only major repair I worry would with my M235. I would consider begging BMW to goodwill some of this repair. It's worth a shot. If you bought used, the prior owner probably did it in by driving it hard before the fluid was fully warmed. These 6MTs use a pretty robust fluid for hard driving, but it's critical that you give the tranny 10-15 minute warm up before hitting the gears hard as the fluid takes a bit of time to warm up. I avoid hammering a 1-2 shift often as the 1-2 syncro is the weak link.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
04-12-2019, 09:08 AM | #3 |
463
Rep 779
Sorry to bring the bad news but from my personal experience the only real fix is a transmission replacement (BMW-covered in my case, twice, but I had to go to another dealer) and possibly also a clutch/dual-mass flywheel replacement (got ripped off on that one to the tune of $4800).
Your synchro grind will only get worse until you cannot shift any more. You can only delay the inevitable, which your dealer may try to do by proposing half-measures. Hopefully your dealer won't do that and instead give you a new transmission, good luck. |
04-12-2019, 10:23 AM | #4 | |
17
Rep 101
04-12-2019, 10:27 AM | #5 | |
463
Rep 779
Just follow a standard warranty procedure: tell your dealer about the problem and that you want it rectified under warranty, they will do a test-drive with you and hopefully confirm there is indeed a problem, instead of trying to weasel-out. Once you have that confirmation, they should start the ball rolling with BMW. |
04-12-2019, 10:33 AM | #6 |
5565
Rep 5,378
Is your car still under warranty? Seeing that it's a 2015, my guess is it's not as the warranty is for 4 years/50K miles (whichever comes first) and the car was likely in service in 2014.
04-12-2019, 10:42 AM | #7 |
17
Rep 101
I need to check on what day the car was purchased to know if it is still in warranty. It’s under 50k miles it just depends when the car was sold so hopefully I can find some info on that and hopefully is still under warranty.
04-12-2019, 11:17 AM | #8 |
3079
Rep 5,578
Put some Red Line trans fluid in and feel if any results. Call them for a recommendation. I'd do the fluid change after you'd have the dealer assess the situation.
https://www.redlineoil.com/heavy-shockproof Probably one of these https://www.redlineoil.com/gear-oil-...-transmissions Last edited by overcoil; 04-12-2019 at 05:52 PM.. |
04-12-2019, 05:10 PM | #9 |
583
Rep 1,117
Drives: 2015 BMW M235i
try the redline fluid change first.
04-14-2019, 08:56 AM | #10 |
180
Rep 772
Drives: 2015 435i grand coupe xdrive
Don't put redline in if you still have a warranty. It will void your warranty
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
04-14-2019, 11:00 AM | #11 |
583
Rep 1,117
u sure? I think as long as it meets spec, should be fine. I dont think warranty says you have to use bmw fluids or the warranty is void...
04-14-2019, 08:44 PM | #12 |
17
Rep 101
04-15-2019, 01:02 PM | #14 |
5565
Rep 5,378
Ask for Goodwill assistance before putting not OEM fluid in the 6MT. You DO NOT want to give them any reason to think that the fluid was the issue. Also, the factory fluid is robust and near race grade. It's also why the fluid requires a bit of time to warm up before beating on it.
