How to Adjust Wheel Size For Different Bumpers and Speedometer?
04-09-2019, 12:04 PM | #1 |
Man Man
24
Rep 242
Hello, I am currently running oem size wheels and installed M3 front and rear bumpers, which leave the wheel gap even larger. VMR told me that for my car (e90 330xi sedan) can run this:
Front: 19x8.5 ET35 // 235/35/19 Rear: 19x9.5 ET45 // 265/30/19 But this doesn't account for the bumpers that enlarge the wheel gap. Also, my speedometer will be off when I change wheels, so what do you recommend I do? Is that something only a dealer can help me fix? Thank you
E90 330xi
04-09-2019, 12:55 PM | #2 |
2124
Rep 2,758
Uhhhmm, your wheel gap will not get any bigger because of the m3 bumpers, they will still be the same distance away from the fender. The m3 bumpers still follow the same wheel arch of your stock fenders, impossible for the gap to the wheels to get bigger.
About your speedometer, your new rim size might be bigger, but you compensate that by getting a smaller sidewall tire which keeps your overall diameter the same size as stock/previous. |
04-09-2019, 01:36 PM | #3 |
113
Rep 513
Drives: 2008 335i
I had 19x8.5 ET +28 and 19x10 ET +30 on my 328 xi, on problem.
Tires get pretty skinny though, and I'm dodging pot holes on known bad roads with these 19". As far as I know, the over all circumference of your new setup needs to be nearly identical to your original setup. keep circumference difference do an absolute minimal as you do have an X drive and you do not want to break your Differential. If you don't change your circumference much, then your speedo will be accurate enough. also, I don't think it's re-programmable as your speed is tied into many other carly functions. Last edited by Pinscher; 04-09-2019 at 01:47 PM.. |
04-09-2019, 04:52 PM | #4 |
Man Man
24
Rep 242
Okay, thank you guys. I think by wheel gap I mean width of the wheel "area"? The bumpers have a wider arch than the OEM. I wish I had a photo of before/after, but it's definitely noticeable.
E90 330xi
04-15-2019, 11:17 AM | #5 | |
Man Man
24
Rep 242
What do you mean by breaking my differential? My original setup is pretty small and I'd definitely like to increase circumference, but I didn't know there would be issues
E90 330xi
04-15-2019, 04:25 PM | #6 | |
113
Rep 513
Drives: 2008 335i
Well if the rolling distance of your rear wheels is greater than the front then the rate the differentials spin at are not in sync. Sorry for lack of technical terms here, but basically your XI will not compensate for large discrepancy, and you can basically ruin your differential or transfer case. This is why XI come with a Square wheel/tire setup, though it's possible to go staggered, provided the rolling distance of your F to R tires is within 5% or so. |
04-15-2019, 04:35 PM | #7 |
540
Rep 1,040
Front & rear bumpers won't increase the area under your wheel arches, unless you also have M3 fenders installed. Pics would help, super easy to upload to imgur and post the link here.
Since you have an XI, you will need to make sure your front & rear rolling diameters are within 3% of each other. The sizes you listed will be fine (647.1mm vs 641.6mm, 0.86% difference). Assuming you are running the stock 18" tire sizes (225/40 and 255/35), you will only be increasing your rolling diameter by 1-1.5%, so your speedometer will read 1-1.5% slower which is negligible (100mph will read as 99mph..)
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon. |
04-15-2019, 09:58 PM | #8 | |
Man Man
24
Rep 242
E90 330xi
04-15-2019, 09:59 PM | #9 | |
Man Man
24
Rep 242
E90 330xi
04-24-2019, 03:52 PM | #10 |
Man Man
24
Rep 242
Here is a photo of my gigantic wheel gap. So I'd be OK with these tire sizes and maybe lowering springs? Front: 19x8.5 ET35 // 235/35/19 Rear: 19x9.5 ET45 // 265/30/19
E90 330xi
04-29-2019, 01:18 PM | #11 |
113
Rep 513
Drives: 2008 335i
I think most people around here would advise to get a proper coil over setup and adjust to your liking. I know little about suspension, sorry .
looks like you have stock base line stuff. an upgrade will do wonders for your drive quality if those are anything like the stock i had an a 328..bouncing all over the place, socially with 19" on there. FYI, it's outside diameter that matters, not the staggered width. I think you got that point though. |
04-29-2019, 04:10 PM | #12 | |
Man Man
24
Rep 242
E90 330xi
04-29-2019, 04:23 PM | #13 | |
113
Rep 513
Drives: 2008 335i
04-30-2019, 12:38 PM | #15 | |
113
Rep 513
Drives: 2008 335i
Though, It really helps to have a house where you can do all this stuff. From there it's a matter of just being handy in that way. some are, some are not. Anyone with welding skills can do the exhaust mod, on problem. it's pretty straight forward welding. Grinders are easily found at a pawn shop. Anyways, you get the point, good luck with your car. |
04-30-2019, 03:56 PM | #16 | |
Man Man
24
Rep 242
E90 330xi
05-01-2019, 10:41 AM | #17 | |
2659
Rep 6,290
Holy shit welding learning curve is pretty steep uh haha! It's a MIG gasless wire. |
05-01-2019, 10:52 AM | #18 |
540
Rep 1,040
What were you going to mod in the 335is mufflers? As far as I know, the popular muffler mods are for the stock 335 exhausts.
05-01-2019, 11:33 AM | #19 |
2124
Rep 2,758
Technically not MIG if its gasless, but I know what you mean. Flux core wire mig welding is harder than actual MIG welding(with gas) in my opinion.
05-01-2019, 11:41 AM | #20 | |
2659
Rep 6,290
But what I wanted to possibly do was straight pipe the left side and have the valve be remote control so I can choose if I want it super loud or normal. But I don't think I'll do that. Right, gas less flux core. Yeah it's not easy! But I think I'm getting the hang of it. I need to practice on stainless steel now. |
05-01-2019, 11:57 AM | #21 | |
2124
Rep 2,758
05-01-2019, 12:00 PM | #22 | |
2659
Rep 6,290
Is there a wire I can just buy that won't rust at all? |
Tags |
gap, rack, speedo, speedometer, tire, vmr, wheels |
