2Addicts
2Addicts
2Addicts | BMW 2-Series forum Technical Topics B58 (M240i) Engine, Transmission, Exhaust, Tuning LSD oil
      04-08-2019, 11:37 PM   #1
MerlinMc
114
Drives: 2020 M240i
LSD oil
Now have a BMW M Performance LSD that I will be having installed on my M240i. Two questions:
1. What is the capacity in liters/quarts for the LSD differential?
2. Recommendations on oil (manufacturer, visc, etc)?
Thanks very much.
      04-09-2019, 10:21 AM   #2
MerlinMc
114
Drives: 2020 M240i
lifetime fluid
I found this post for the M235i that suggests the LSD comes with "lifetime" fluid. The part number for the M240i is different however.
https://www.2addicts.com/forums/showthread.php?t=982939
      04-09-2019, 12:20 PM   #3
Pray for Mojo
430
Drives: 2014 M235i & 2018 X3 M40i
I had mine changed after 2,500km.
      04-09-2019, 05:23 PM   #4
MerlinMc
114
Drives: 2020 M240i
thanks and further question
Thanks. What oil did you use for the replacement. LSD oil I assume, but was it 75-95 or 75-140? Brand?
      04-11-2019, 11:55 AM   #5
Pray for Mojo
430
I used the OEM BMW differential oil, I think it was 75W-85, but not sure.
      04-12-2019, 11:17 AM   #6
Dylan86
Dylan86's Avatar
1330
Drives: F15d msport, F22 m235i
Ditto, OEM fluid and changed at 25k kms.
For the MT gearbox I'll be using a Redline gear oil instead. Not changing until next winter, though..
      04-12-2019, 11:39 AM   #7
Pray for Mojo
430
Only thing I would caution going non-OEM on gearbox oil, it can make it tough to shift into 1st when cold.
      04-16-2019, 07:47 AM   #8
Dylan86
Dylan86's Avatar
1330
Yea, typically the "track" duty gear oils take a while to warm up. Redline "synchromesh" (I think) is what I used in the past, never effected shifting, negatively, and if anything made the VW/Audi gearboxes much smoother..
2addicts
