BMW 1-Series Forum (F20) 135i - 1Addicts.com > Second Generation 1 Series Forum > DIY Guides and Instructions > Bmw iDrive Controller change
      03-30-2019, 06:25 AM   #1
mschembri1996
Malta
Drives: Bmw F20
I have iDrive Controller like the one in the photo, is it possible to change to the big one? if yes how can i do it because i cannot find anywhere how, i appreciate the help, thanks.
      04-01-2019, 01:37 AM   #2
88tuning.id
88tuning.id's Avatar
Indonesia
39
Drives: E39 520i Msport
Hi, i'm doing this kind of retrofit on my friend's car, i havent finish it, but here's the step im doing last week:
1. Check either your old controller is connected to KCAN1 or KCAN2 From factory, to differentiate it K-CAN wires are green and orange and K-CAN2 wires are yellow-red and yellow-brown. If your car has KCAN1, it should need another module to plug the controller. since my friend's car has KCAN2 from factory, so i didnt look the module.
2.Minimum build date (Zeitkriterium) of your car to be 07/13
3. The NBT needs to be flashed to at least 50.4 psdzdata.
4. Some coding in HU NBT
HU_NBT/3000_HMI/ZBE_TOUCH_INTERACTIVE_MAP set to aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_SPELLER set to aktiv
HU_NBT/3000_HMI/ZBE_TOUCH_BROWSER set to aktiv
HU_NBT/3004_SYSTEM/EINSTELLUNGEN/ZBE_TOUCH set to aktiv
Goodluck!
hope this helps.
T
Instagram: @tafikhulafaa & @88tuning.id
      04-02-2019, 03:33 AM   #3
mschembri1996
Malta
Drives: Bmw F20
Thank you so much for your help!!
      04-12-2019, 03:57 AM   #4
No one
1030
Drives: F21 118i
Lightbulb A cross-link.
Here's a simple solution, perhaps: https://f20.1addicts.com/forums/show....php?t=1603250. It should remove the interface (connection) restriction/complicacy as well as coding. The same buttons (no dead ones added). FWIW
Search this Thread:
Advanced Search
1addicts
