03-29-2019, 01:24 PM | #1 |
BMW obsessed
9587
Rep 10,877
IND | 3D Design Carbon Shift Paddle Set
The 3D Design Carbon Shift Paddles are designed to infuse a sleek and lightweight feel right into the drivers seat, all with a unique carbon fiber weave. Made with a dry carbon process, every step that goes into making these shift paddles is meticulous to further ensure quality. With a delicate mille-feuille layering process, carbon pre-preg sheets are formed to a 5mm carbon fiber board through careful heating and pressure. After this, the paddles are machined from the sturdy yet lightweight dry carbon board. This process is similar to aluminums process, but since carbon fiber is so strong, extra time is taken to guarantee quality. To finish off this impressive process, the carbon shifters are painted in a beautiful clear coat that will not only look great, but also block UV in the process. The end results are carbon shifters that are easy to handle, fit perfectly in your hand, and are as stylish as they are efficient.
03-29-2019, 05:19 PM | #2 |
153
Rep 427
Drives: 2019 M5 Competition
Those look amazing! What's the install like?
02-02-2020, 11:03 PM | #5 |
12968
Rep 18,713
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
04-07-2020, 04:46 PM | #6 |
BMW obsessed
9587
Rep 10,877
Installation is fairly straight forwardit mimics pretty much every 3D Design paddle install we've completed so far. You can take a look at some of the reference photos here:
https://www.flickr.com/photos/592410...57668991954547 It essentially requires removal of the OEM steering wheel / airbag to gain access to the stock paddles. Once out, you'll insert the 3D units in their place. Fully plug and play. Here's a photo of the OEM paddle vs the 3D unit for good measurehuge improvement.
04-21-2020, 09:29 AM | #10 | |
BMW obsessed
9587
Rep 10,877
If it's the latter, I'd probably opt to do so with a set of the aluminum paddles personally so you wouldn't be painting over the gorgeous carbon. I've attached a photo of an aluminum set that we painted before with black upshift / downshift indicators. Let us know!
04-21-2020, 04:31 PM | #12 |
199
Rep 235
2020 M5 Comp
2019 i3 Rex 2010 Z4 35i |
EPTXM577.50 |
04-21-2020, 04:48 PM | #13 | |
BMW obsessed
9587
Rep 10,877
04-23-2020, 03:23 PM | #14 |
38
Rep 66
Hi.
Can anyone post a video or very detailed description of how to remove the air bag and centre part of the steering wheel? I assume as soon as you detach the battery then the airbag cant go off? |
04-23-2020, 03:39 PM | #15 | |
Just A Regular Guy
318
Rep 242
Drives: G80 M3 Competition X-Drive
05-10-2020, 10:04 AM | #16 | ||
392
Rep 279
