BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CCC to CiC Upgrade
      03-24-2019, 08:39 AM   #1
jokers_greg
Master of Montego Blue
jokers_greg's Avatar
28
Drives: 2007 BMW 335i
2007 335i  [0.00]
CCC to CiC Upgrade
So I have been trying to sell a bunch of parts I bought with the intent to upgrade my CCC to CiC unit. Unfortunately I had a few unexpected repairs and some upgrades come up so I need the money.
There has been little interest so at this point I'm considering just doing the upgrade anyway. But I have a couple of questions:
1) My CCC is a Top-HIFI system, are all CiC head units Top-HIFI compatible (i'd rather not lose sound quality or speakers)
2) Will I be able to use this Aliexpress USB/AUX connector instead of the OEM BMW USB cable that plugs into the unit?
3) Where's a good place to buy that pink connector that connects the head unit to the display?
      03-24-2019, 12:27 PM   #2
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
DO NOT BUY AFTERMARKET HSD FARKA CABLES
I get all my HSD wires from here: https://www.trademotion.com/partloca...?siteid=214320
The CIC is compatible with any audio system, in any E9X. All you need to do is code it properly.
      03-24-2019, 02:03 PM   #3
jokers_greg
28
2007 335i  [0.00]
OK so I'm just looking for the usb/aux HSD wire, and the connector between display and CiC unit?
The CCC has just an AUX port in the center console armrest, can I make that a usb/aux instead?
      03-24-2019, 02:37 PM   #4
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
You would need to retrofit a combox for a center console USB port
      03-24-2019, 03:00 PM   #5
jokers_greg
28
2007 335i  [0.00]
so without a combox I should just route the usb one to my glovebox like I've seen, and keep the aux in the center console?
      03-24-2019, 05:44 PM   #6
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
Correct
      03-25-2019, 12:52 PM   #7
jokers_greg
28
2007 335i  [0.00]
Thanks, all of this information is just sort of spattered all around the forum and unfortunately there is no clearly written sticky that captures everything.
      03-25-2019, 02:14 PM   #8
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
Even my CIC DIY guide is a pile of crap. I need to go around and make changes to a few of my guides.
      03-26-2019, 07:11 AM   #9
jokers_greg
28
2007 335i  [0.00]
Actually I found it the most useful. I would appreciate things like part #'s but also options. What is required, what is optional, why is it optional etc.
It looks like I'll be doing the swap soon so I can help with the write up if need be, that being said, clearly I'm new to this haha
      03-26-2019, 10:17 AM   #10
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
61119185171
61136954526
61319167196
61129255716
These are the required part numbers for the wires.
      03-26-2019, 11:04 AM   #11
ptpending
ptpending's Avatar
456
Drives: e91
i still have genuine cables which i can sell
https://www.e90post.com/forums/showthread.php?t=1483482
E81 2007 130i 6cylinder Montego blue
Retrofits: Harman Kardon, High-beam assistant, Removable tow hitch. Auto-dim folding exterior mirrors. Lumbar support. Perfomance Brakes.
      03-26-2019, 08:36 PM   #12
jokers_greg
28
2007 335i  [0.00]
got any favourite tool for re-pinning? Ideally something on amazon? Or will a set of precision screwdrivers do just fine?
      03-27-2019, 02:38 PM   #13
dylim
14
Drives: 328xi
They'll do fine, or picks from harbor freight. Anything that allows you to press down the tab.
      03-28-2019, 01:53 PM   #14
jokers_greg
28
2007 335i  [0.00]
https://www.amazon.ca/Kalolary-Termi...gateway&sr=8-5
Work the pickup?
