03-22-2019, 03:35 PM | #1 |
123
Rep 353
Anyone on here with RE71R or R888R with pics?
I'm looking to get a square set up year round, and I like that beefy summer tire look.
The widest tread width that exist for our cars in 285/35/20 is the RE71R where the 285/35/20 is actually wider than the average 295 tire, and the R888R (obviously the R888R overall is not a good idea for a street tire) where the 285s are almost identical to the average 305 tire. Is there anyone here that has successfully installed either tire on their car with 11/12mm spacers? Would be great if you could post some pics! |
03-31-2019, 12:08 PM | #2 | |
1830
Rep 1,315
03-31-2019, 06:28 PM | #5 |
123
Rep 353
Wow, so you have R888R all around? Are they on OEM 20"? Do you have spacers, do they rub?
Thanks! No clue where you can upload them, maybe someone can chime in? |
03-31-2019, 07:54 PM | #7 | |
1830
Rep 1,315
No rubbing. Track next week. The stock Michelins lasted six track days. These will be much stickier. We'll see how long they last. Shawn |
04-01-2019, 12:22 PM | #8 |
123
Rep 353
Wow, damn, I need to know if it's possible to throw 11mm spacers front and rear with these, I highly doubt the rears will clear but damn that looks aggressive!
04-01-2019, 12:30 PM | #9 |
1830
Rep 1,315
04-10-2019, 07:55 PM | #10 |
1830
Rep 1,315
These tires were good and fairly sticky for the first three hours on track...
Pressures were hard to regulate. These heat up A LOT. Had to put the starting pressure low to get to the recommended 35 psi hot that Toyo recommends. They still fell off after THiS happened: |
02-29-2020, 06:16 PM | #13 | |
348
Rep 1,237
what PSI do you recommend
03-22-2020, 08:32 AM | #14 | |
1830
Rep 1,315
Need to aim for 35 psi HOT. This was hard to keep consistent. Other problem - they were LOUD. Randy Pobst went out of his way to come to my garage thinking I had a differential problem. It was just the tires. They make a very ugly high speed whine that sounds like gears going bad. Shawn |
