03-19-2019, 06:12 AM | #1 |
2924
Rep 1,303
Drives: 2021 C8 Corvette 1LT
2019 and 2020 g29 z4 wheel specs
Factory specs below:
Bolt pattern: 5x112 Center Bore: 66.6mm Bolt: M14 x 1.25 Torque: 140nm (103 ft lbs) Factory 18s: 8"x18"et20 9"x18"et28 225/45 front tire 255/40 rear tire Factory 19s: 9"x19"et32 10"x19"et40 255/35 front tire 275/35 rear tire Here are some wheel options that were pulled from Tire Rack (TR) and 1010tires. Both have been reliable in the past for aftermarket wheels that fit on stock suspension without any modifications: FRONT: 9et35 - 3mm closer to strut, 3mm further from fender (TR) 9et30 - 2mm from strut, 2mm closer to fender (1010tires) 9et25 - 7mm from strut, 7mm closer to fender (1010tires & TR) 9et20 - 12mm from strut, 12mm closer to fender (1010tires) 9.5et30 - 4.3mm closer to strut, 8.3mm closer to fender (TR) 9.5et25 - .7mm from strut, 13.4mm closer to fender (TR) 9.5et26 - .3mm closer to strut, 12.4mm closer to fender (2018 m5 19" wheel) REAR: 10.5et30 3.7mm from strut, 16.4mm closer to fender (1010tires) 10.5et42 8.3mm closer to strut, 4.3mm closer to fender (TR) 10.5et38 4.3mm closer to strut, 8.3mm closer to fender (TR) 10.5et35 1.3mm closer to strut, 11.4mm closer to fender (TR) 10.5et28 5.7mm from strut, 18.4mm closer to fender (2018 m5 19" wheel) The M5 19" wheels should theoretically fit since they fall within the ranges confirmed by TR and 1010tires (with the exception of the rear 10.5" which is only off by 2mm from a confirmed fit). If you're looking for more grip, then MPS4S are the best out there without going streetable autocross/track tires. 275/30ZR19 MPS4S Recommend 9.5" wheel ($312.99) 295/30ZR19 MPS4S Recommend 10.5" wheel ($349.99) 305/30ZR19 MPS4S Recommend 11" wheels, but the mounting range starts at 10.5" ($377.99) Yes, the 275/30 and 295/30 are smaller overall diameter than the factory 255/275, but only marginally and would cause a speedo error of ~2%, or .6mph (speedo reads 30mph, you're actually doing 29.4mph, radar gun would probably read 29-31mph depending on level of accuracy). Last edited by Joe240; 08-19-2019 at 04:19 PM.. |
05-22-2019, 08:45 PM | #2 |
2924
Rep 1,303
Did some measurements this evening on inner and outer clearances for front and back wheels. Finding wheels that would sit within these measurements will allow the 275/295 wheel setup.
Front: 10mm from strut 8mm from fender Rear: 25mm from strut 12.5mm from fender Updated the OP as well to reflect this. Wheel sizes in Red will still fit the vehicle, but smaller width tires will be needed (255 in front instead of 275, 285 in back instead of 295). Also, the m5 wheels will fit, but there would be ~1-3mm of poke on the wheels, so smaller tires would be required (again, 255/285 would probably be best). Last edited by Joe240; 08-19-2019 at 05:00 PM.. |
08-19-2019, 04:59 PM | #3 |
2924
Rep 1,303
Using the ECSTuning spacer fitment rental kit, I found the following spacers will bring the wheels flush with the fenders:
8mm front 12-13mm rear (12.5mm is exactly flush) ECSTuning offers a 12.5mm spacer for the rear with extended lug nuts, but other manufacturers may only offer 12 and 13mm. This is why I did a range instead. If looking at aftermarket wheels, the following sizes would clear the fender and suspension. The lower offsets would make the wheels flush, so they are advised for stock suspension only, not lowering springs: 19 x 9.5 et30 to et33 ideal for front 275/35 (or 275/30) 19 x 9 et24 to et40 ideal for front 255/35 19 x 11 et42 to et48 ideal for rear 305/30 19 x 10.5 et35 to et52 ideal for rear 295/35 (or 295/30) |
09-17-2019, 11:16 AM | #5 |
2924
Rep 1,303
No really isn’t a lot. Someone said aftermarket 19s don’t clear the brakes and that’s why the big company’s went with 20s and that doesn’t make sense. Based on my measurements, a low offset 18 should also fit front and rear.
I’m considering 18s for the added sidewall for launches and ride comfort, but thinking it might look ridiculous. |
09-17-2019, 11:36 AM | #6 |
61
Rep 106
I feel 18s might be too small?? Are you planning on lowering? Not sure if any springs are available but always had good luck with eibach pro-kits. Great comfort/performance balance
09-21-2019, 12:43 PM | #8 |
2924
Rep 1,303
H&R has lowering springs for the z4/supra (and I'm sure other manufacturers who only advertise for the supra). I've considered lowering but I like the ride comfort of the stock suspension. Still on the fence.
Pictures with the flush spacers are in the thread here: https://g29.bimmerpost.com/forums/sh....php?t=1639045 |
09-21-2019, 12:46 PM | #9 |
2924
Rep 1,303
and I've considered going 18s because of the thicker sidewall. Would allow for a more comfortable ride if lowered, but also more sidewall for flex at launch (allows for better launches when running lower PSI).
JustChris17483.00 |
01-25-2020, 08:00 AM | #10 |
11
Rep 5
Stock 799m wheels weight
Hi All,
Does anyone knows or had weigh before the stock 799m 19inch wheels? Thinking whether to change them out for lighter wheels. Thank you for any reply in advance. |
01-29-2020, 11:02 PM | #12 |
2924
Rep 1,303
01-30-2020, 07:10 AM | #13 |
255
Rep 408
Garage
2014 Z4 35is RIP /2016 Z4 28i RIP 2015 335i RIP 2016 Audi A7 RIP / 19 Genesis G80 RIP 2020 Z4 M40i / 2022 X3 |
01-30-2020, 08:25 AM | #14 |
2924
Rep 1,303
Did you do the 8.5/9.5 stagger or square 9.5?
01-30-2020, 04:08 PM | #15 |
255
Rep 408
Didn't order yet but i did the math and staggered set seems Fine. 15mm spacers in rear. Stock Rims are 10 inch with 40 offset. These wheels are 9.5 inches with 38 offset which means they are 12mm shorter. 6mm inside 6mm outside. With 38 offset they will tuck in 2mm more. Since rim is 6mm less on inside no chance of rubbing there. However it will be tucked in to much and a 15mm spacer will solve the problem. Wheels will stick out 7mm more. Which will look fine. Not enough for my taste though. I will figure fronts latter. If my math is incorrect, please offer input.
Garage
2014 Z4 35is RIP /2016 Z4 28i RIP 2015 335i RIP 2016 Audi A7 RIP / 19 Genesis G80 RIP 2020 Z4 M40i / 2022 X3 Last edited by gasnet; 01-30-2020 at 04:11 PM.. Reason: spell |
01-30-2020, 04:10 PM | #16 |
255
Rep 408
Positive offset on left. Which is most popular
Garage
01-30-2020, 04:18 PM | #17 |
2924
Rep 1,303
One of the best websites I've found for wheel spec comparison is willtheyfit . com
9.5et38 will place the tire basically where it is from the factory, but the wheel itself will sit 4.4mm in from where the factory wheel is. Since a 12.5mm spacer on the stock wheels will make it flush, you can add the extra 4.4mm inwards that the new 9.5" wheel allows so you can do up to a 16.9mm spacer (call it 17mm). I think a 15mm spacer will do fine with those new wheels definitely post up pictures when you get them mounted
Project Car: DF Goblin
-Built LSJ-T 2021 C8 Corvette 1LT 2021 Model Y Performance |
JustChris17483.00 |
01-30-2020, 04:27 PM | #18 |
2924
Rep 1,303
Honestly, you could order a square 19x9.5et38 and run a 5-8mm spacer in the front and the 15mm spacer in the rear. Then you could do 275/35/19 front and rear for tire rotation if you wanted.
Otherwise, the 19x8.5" wheels you could run an 8.5et46 (closest time suspension) at most and 8.5et18 (flush) at the least. But you'd probably have to run a 235 or 245 at either extreme to avoid rubbing (255 bulges a bit on 8.5" wheels).
01-30-2020, 04:30 PM | #19 |
255
Rep 408
Thanks for the website tip. Might stay with stock rims i love them. My previous Z4,s i was never crazy about rims and hated the Runflats. Always ordered rims tires and sensors. Kept original in shed for lease return. Also i thought summer tires would be a problem, but i just take it easy in the cold. Love my stock wheels.
Garage
02-02-2021, 02:00 PM | #20 |
is FTW!
Rep 44
Want to clarify when i referenced this post before buying the Z4 but my M40i came with the factory 18s but not at the size you posted:
Factory 18s: 8"x18"et20 9"x18"et28 225/45 front tire 255/40 rear tire once I find time I will get the car up and check the wheel size and offset. But the car came with 255/40/18 fronts and 275/40/18 rears Michelin PS2s.
RIP: 01.5 Santorin Blue 2+ S4, 01.5 Nogaro Blue Avant Stage 3- S4
05-02-2023, 04:05 PM | #21 | |
Rep 6
05-02-2023, 04:31 PM | #22 |
981
Rep 1,560
Just be aware, as tonggi said, these spec are for early G29s and are not the same as the later G29s. Also, the options can effect the tire specs.
2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, HT, TC Kline DA Shocks & Camber Plates, w/H&R Springs, Stromung Exhaust, SSR Type C. Looking for new home.
2022 Z4 M40i, Misano Blue Metallic, Driver Asst Pkg, Prem Pkg 2023 X5 M50i, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg. |
