The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > Help needed swapping I-drive components to non I-drive car
      03-16-2019, 04:51 PM   #1
Serf27
Serf27's Avatar
2851
Drives: 335i
Hi all, it’s time I finally add I-drive to my car.
I have my e90 335i that has almost all fbo mods installed and will keep having money thrown at it, but is getting very wore out from using it as a daily.
I just purchased an 07 335i with the upgraded I-drive stuff, individual tpms on screen, oil level on screen etc etc. This would be the new daily.
So I have the new car that would have all the parts I could need, besides coding.
I want to know what I need to swap over from 1car to the other please.
I know the dash and the screen but what specific modules would also have to swapped over.
I have seen the diy on the 1addicts site but I believe they use the older I drive system, would it still be the same thing?
You’re probably thinking why don’t I just swap mods over to the idrive car.
The non I-drive has had m tech bumpers painted and installed and lci trunk/taillight installed and painted.
I would rather swap I drive parts from one to another.
Really wanna do this swap. Any help would be appreciated!
Thanks in advance.
      03-17-2019, 04:28 PM   #2
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
Thanks in advance.
https://drive.google.com/file/d/0By4...R0OXhMS3M/view
Non idrive to CIC is about an 8 hour job. It is not that hard.
      03-17-2019, 06:05 PM   #3
Serf27
Serf27's Avatar
2851
Drives: 335i
Thank you for that.
I have seen that diy. The user used a ccc.
Does that diy cross over exactly to a cic swap? As far as the wiring.
      03-17-2019, 06:12 PM   #4
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
Thank you for that.
Is is the same thing except you need to run a Chinese emulator or flash the CIC with new FSC codes. You will also not need to pin in a fan harness.
      03-17-2019, 08:58 PM   #5
Serf27
Serf27's Avatar
2851
Drives: 335i
Ok either flash the FSC codes or the emulator right?
Does the cic not have a fan? Or why wouldn’t it need a harness.
Also the cic idrive Car has the usb/aux plug in the center console.
Would that involve swapping the module in the trunk over also so the USB/aux plug work too?
      03-17-2019, 09:31 PM   #6
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
The CIC has an internal fan and not a external one. You will need either a combox or MULF module in the trunk to retrofit the center console USB.
      03-17-2019, 11:21 PM   #7
Serf27
Serf27's Avatar
2851
Drives: 335i
Ok thank you.
The idrive car already has the mulf module since it is equipped with the usb.
Do I just unplug it from that car and plug it in the non I drive car and it will work?
Or does that require extra wiring in the trunk and the center console?
      03-18-2019, 02:34 PM   #8
6ixSpd
Save the manuals!
6ixSpd's Avatar
6016
Drives: '16 M3, '23 718 Spyder
Read up on a MULF retrofit. That will answer your questions.
'16 M3 | '23 718 Spyder
Past: E92 M3, F87 M2, E39 M5, etc
