BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Tire pressure
      03-15-2019, 02:37 PM   #1
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Tire pressure
Hello,today i have changed my winter setup and put summer.
However i have a problem.
I have switch to 20 inch summer wheeels in menu,but i have a problem with tire pressure.
I have put 2.5,but comp said that recomended is 2.8 and after that 3.0
In psi that is almost 40,which i find too much.
How to change that recommended value?
Because when u put my settings,a get alert message to drive moderately.
What should i do?
Thanks Deda
      03-15-2019, 03:01 PM   #2
M135iXdriver
M135iXdriver's Avatar
Switzerland
200
Drives: BMW M5 Competiton
Location: Northwestern Switzerland veeeeery close to the German Autobahn
What should i do?
Thanks Deda
I really am not sure but I thought it works this way:
- set the tire pressure you want
- reset tpms
After this the system takes over the pressure your tires have and automatically sets a threshold for the lowest possible value.
It's the first time I see this "recommended tire pressure" - maybe BMW changed something in the last few years. Let's wait for another opinion just to be sure.
Prijatno vece
2019 - BMW M5C MY2019 (Individual Urban Green)
2016 - VW Passat B8 2.0 TSI (276 bhp) R-Line (sold)
2013 - BMW M135i xDrive 3.0 (316 bhp) (sold)
2010 - Mazda 3 MPS BL 2.3 (256 bhp) (sold)
      03-15-2019, 03:03 PM   #3
marcvtec
407
Drives: M5
2.9 bar is 42 psi, wow.
Something is wrong and I would goto the dealer.
My car suggests 35 PSI, (2.4 bar) for reference.
My old 335 said for max passenger load, on the door was 42 psi on a 30 profile tire running 19 inch. for normal load was 38 psi.
Otvoreni - out
      03-15-2019, 03:12 PM   #4
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Thank you guys! I was shocked too.
Maybe someone else faced this problem.
Slatke brige.😊
      03-16-2019, 06:05 PM   #5
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
I run mine at 42 psi. Drove RS6 15 years, 150,000 miles, pressure at 42 psi. Prior M3 5 years 75k miles, 42 PSI, A8L 42 PSI, M2, 42 PSI. 42 is the best....
LOL
Mike
2018 M5 and 2019 Porsche Boxster GTS
Prior. '94 325is, '97 M3 Lux, '16 M2
      03-17-2019, 03:13 AM   #6
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Aronis..now im confused even more..this 42 psi is recommended from car computer.
However i feel its too much and im afraid that my tires will gone much faster...
Can i change that recommended settings?
Anyone? I will really appreciate your help and info.
Thank you!
      03-17-2019, 05:21 AM   #7
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
Thank you!
Ignore that setting and experiment I run mine @ 34/35 PSI all round.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      03-17-2019, 07:34 AM   #8
M135iXdriver
Switzerland
200
LOL
Mike
This equals 2.9 bar which seems a bit too much. I would run 2.5 all around which equals 36 psi. How does the wear off your tires look like? Or was your car always loaded that you used this higher pressure?
      03-17-2019, 08:35 AM   #9
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
I get nice even wear. I have found that running lower pressures provided noticeable softer ride, handling not as crisp.
Funny, I had a few times when I was not keeping track of tire wear when I wore the things down to slicks completely evenly. Failed inspection with my winter tires on my RS6 once (was crazy busy and was not doing my usual car check routine) and in my '97 M3 I used to milk ever last drop of tread out of my Michilin PS1's.
In the winter you'll find older mechanics lowering the pressure in your tires for you with the OLD belief that it improves snow traction. That is false. What improves winter traction is using winter tires LOL.
Mike
      03-17-2019, 03:49 PM   #10
marcvtec
407
Drives: M5
Ummmm...
My stupid computer that is built into the BMW says 35 PSI recommended pressure. The question is, why does his say 42 PSI ?
Europe ? Deda is fat ? maybe running a full load all the time ? <-- enter jokes.
Something is off.
Deda, do you have a sticker inside your drivers door ? what does that say ?
      03-17-2019, 03:59 PM   #11
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Well thats the problem..it says 34...
I am going tomorrow to dealership to check situation.
If somebody have something to add..please do..
And im not a fat....😊
      03-17-2019, 04:08 PM   #12
marcvtec
407
Drives: M5
Ya bro just keep it at 34 and tell them your dumb computer has a problem
      03-17-2019, 07:12 PM   #13
Roger_W_Martin
Roger_W_Martin's Avatar
Argentina
Drives: BMW M5 F90 2018
Is it normal for the left front wheel to always work at a higher temperature? I've always done it in my car
      03-18-2019, 05:37 AM   #14
JSR2018
30
Drives: BSM F90 Competition
I asked this same question, related to the oil cooler I believe!
My M5C wants 42PSI according to the information inside the door (sticker). I run at that, I was surprised at how high it is as well.
      03-18-2019, 08:24 AM   #15
Aronis
Aronis's Avatar
2272
Drives: 2018 M5
My comment was tongue in cheek, my car reports recommended pressure of 41 for front and 40 for rear, and that is where I have mine.
Mike
      03-18-2019, 04:07 PM   #16
marcvtec
407
Drives: M5
My Non-comp door sticker says 33psi front 34 psi rear.
What I am wondering is how it can be so different, considering same rims size and vehicle weight. ? Does not matter the suspension, very weird.
bubbaboy107.50
      03-21-2019, 04:35 AM   #17
M135iXdriver
Switzerland
200
Any news?
      03-21-2019, 05:23 AM   #18
JOHNBMWM5
JOHNBMWM5's Avatar
1989
My M5 CP says 33 front 34 rear in temperatures of 8deg celsius. which is about right, 40PSI is a joke, must be like riding on bricks
      03-21-2019, 08:02 AM   #19
Deda
Deda's Avatar
Croatia
564
Drives: BMW M5 comp
Well,i was at dealership and they told me that u need to listen what computer said...well i was not expecting more from them.
I just lower the pressure to 34 and every time i wake up beast i get a message to check tire pressure..
So far so good..no restrictions on speed.
      03-21-2019, 09:02 AM   #20
F90M5C
F90M5C's Avatar
Sweden
155
Drives: 19 F90 M5C,17 F82 ZCP M4
getting the check tire pressure each time is so annoying ,im switching back to summer this weekend or under next week , can't wait , hope not to get any problem . I have the 20'' winter tires with same dimensions as my summer ones .
      03-21-2019, 12:02 PM   #21
mhh
80
Drives: Audi RS6
Are you looking at the 20” section of the placard in the door jamb?
      03-22-2019, 12:16 AM   #22
M135iXdriver
Switzerland
200
Balkanska posla, samo da su prodali auto i posle ih boli da ne kazem sta...
Balkan stuff, they just want to sell the car... expect nothing after that.
m5post
