265/40/18 Rear?
03-13-2019, 09:28 AM | #1 |
47
Rep 259
265/40/18 Rear?
hey guy quick question here. This my current setup
Front 18/9 ET38 225/35/18 Rear 18/10 ET33 255/35/18 I am also running 5mm spacers on all 4 corners and currently the stock sport suspension, My question is that stock tire size is somewhat stretched out so I wanted to go wider. Will I have any rubbing issue if I go with this tire size on the same rims? Also I just purchased a set of Eibach Sport Springs so the car will sit lower. Should I go with a 35 aspect ratio instead of 40? Front 235/40/18 Rear 265/40/18
2007 e92 335i 6 speed FBO
CPE Catted HiFlo DP's BMS SSK & JB4 |
03-13-2019, 11:08 AM | #2 |
3537
Rep 3,049
I have Michelin PS4S 235/40/18 and 265/35/18 on my '09 E92 with 189's. The suspension is stock and I'd suggest doing springs, shocks and struts before tires. You need to see how it settles and then the tires.
03-13-2019, 11:12 AM | #3 |
47
Rep 259
yeah that's a good thought, I was gonna put the springs on anyway before the tires. I was just hoping someone else had a similar setup
03-13-2019, 04:23 PM | #4 |
20
Rep 183
I think you should be fine in the rear. I have 255/35/19 on my rears with no problems. This is equivalent to 255/40/18.
Also my car is LCI E92, and I believe I have less space in the back than the pre-lci. So you should be fine with the 265. But you'll have a bigger difference in overall diameter between front and back. 265/35/18 will get them closer. |
03-13-2019, 05:04 PM | #5 |
47
Rep 259
thanks for the advice yeah I may run the 265/35 on the rear and the 235/40 on the front.
gonna get my suspension setup first, just purchased some Eibach Sport Springs
03-25-2019, 11:38 AM | #6 | |
540
Rep 1,040
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon. |
03-25-2019, 07:12 PM | #7 | ||
20
Rep 183
03-26-2019, 08:32 AM | #8 |
540
Rep 1,040
You da man. I was planning to run this size on my style 225s, so same size front and rear as your 313s
03-26-2019, 09:14 AM | #9 |
20
Rep 183
03-26-2019, 10:23 AM | #10 |
540
Rep 1,040
I have 235/35/19s for the front, I just need some new rear tires now.
