03-12-2019, 12:10 PM | #1 |
272
Rep 823
Anyone using 5mm spacers?
So I'm about to order a set of 5mm spacers to get my 18x8 ET40 flush flush with the rear fender. I came across this note on the ECS website and was wondering if anyone has 5mm spacers and can confirm that they will stay hubcentric.
03-12-2019, 06:18 PM | #2 | |
4445
Rep 3,504
If you can't get a definitive answer here, you might try an independent - say, like Pacific Motorsports 503-278-4271. Come to think of it, ECS should be able to answer your question for you. If you get desperate, I'll remove a wheel and take a picture for you.
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; GTechniq Crystal Serum Ultra Ceramic; Suntek PPF |
hwntime272.00 |
03-12-2019, 06:22 PM | #3 | |
272
Rep 823
03-14-2019, 12:01 PM | #4 | |
114
Rep 448
Post from B58togo on 5mm spacer
"I have 5mm ECS Tuning spacers with my Apex EC-7's and I'm not losing sleep over any possible negative consequences. They weigh nothing, car rides smooth, and realistically, since the wheels are around 4lbs lighter each than OEM wheels, it's a non issue. Of course, when I go to put the OEM wheels (with Pilot Alpin PA4's) on this weekend, I'm sure the spacers will be stuck to the hubs, so I'll just run them through winter. Now if you're running 30mm spacers with heavy 20's and you're slammed with -4 camber, there may be side effects." Here's a link to the thread: https://www.2addicts.com/forums/show....php?t=1439801 |
03-15-2019, 11:07 PM | #5 |
809
Rep 1,372
Still no problems. I run the spacers with the EC7's April to November and with the stockers November to April.
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
03-16-2019, 03:02 PM | #6 |
272
Rep 823
03-16-2019, 05:51 PM | #7 |
284
Rep 566
that’s right. 5 mm are kind of dicey depending on the wheel design you use. the hubs may in fact not protrude enough to keep the wheels hubcentric.
I used 5 mm spacers with stock wheels and there were only about 2 mm on which to center the wheels which could easily have been a problem should I had hit a serious pothole or something. I can imagine I could have easily damaged the hub or the whole assembly. Just didn't inspire too much confidence. Looking at the back pad of different wheels I can imagine there may be wheels that won't work, won't center, with 5 mm spacers. It's not just how much of the hub is protruding it's also about design of a specific wheel. Last edited by x233; 03-16-2019 at 05:57 PM.. |
hwntime272.00 |
03-17-2019, 03:10 PM | #8 | |
272
Rep 823
03-17-2019, 05:40 PM | #9 |
284
Rep 566
to be clear: there is more mm protruding but there is only about 2 mm to actually center the wheels on (where the inner bore of the wheel back pad has contact with the protruding part of the hub). also, it's a good idea to try new wheels first to see if they work with 5 mm spacers.
hwntime272.00 |
