03-09-2019, 08:41 PM | #1 |
2925
Rep 1,303
Drives: 2021 C8 Corvette 1LT
S55 disappointment after test drive with an M3
So I went to the dealer this afternoon to discuss a M2C. Worked out the numbers for everything and I was satisfied with how everything had gone so far. Knowing it wasn’t the N55 anymore and I have never drove the S55, I wanted to do a test drive. Luckily, there was a used ‘18 m3 on the lot for me to see how the engine responded. I couldn’t believe how disappointed with it I would be. I made sure it was up to operating temp first and did a red light launch, as well as 3-4 other launches in front of the dealer before going back and some rolling pulls. All left me disappointed, thoroughly disappointed. I expected performance similar to my m240ix (not launches, but rolling pulls for sure). None of it was close.
Coming from a ‘17 m240ix with jb4, CAI, sport cat DP and Remus exhaust, I know my hp and ya are already higher than the m3, but not by much I feel. To me, it was more of the power delivery of the S55 that left me deterred. From a lunch, held the brake and gas gas up to 2k, jumped off the brake and floored the gas and the rpm dropped to 1k, slowly moved forward like it was just being pushed from behind, and 1-2 seconds later the power kicked in and just broke the tires loose. Once it did grab traction, it felt no different than my 2 series does stock (I know because I did a pull after the dealership without my jb4 and CAI on the car this evening). From a roll, it felt a tad stronger than my car, except above 5.5k where the b58 falls off (again, without the jb4 and CAI). Is this behavior due to the s55 tuning where the torque is detuned down low? For those of you with an m3/4, did a DP and flash fix this issue? I know these can make stupid power, but the factory delivery is garbage I feel unless moving and keeping it high in the rpms. Traction will always be an issue unless putting better tires on, I know, but from a roll I’d expect better power delivery. For the test drive: ‘18 m3 with dct and 3200 miles. Did a stop, brake and gas to 2k and then dump brake and full gas. Also did a full off brake and just mashed the gas which seemed to be a little better with the delivery (yes tires spun, but it was how soon tires spun and engine revved that was better than brake/gas first tried). From a roll I was doing 15 floored to 80. Felt good up high, but until it hit 3-4K it wasn’t amazing. I’d like for it to just go when I hit the gas like the B58 does. Looking for some serious feedback because right now I might look towards a v8 or the q60rs or something like that. I love my m240ix, but looking for more power and uniqueness (already few 2series here in the pan handle, but even fewer m2 here as well). If there’s anyone in the fwb/Pensacola area on the forums with an m3/4 or m2c that wouldn’t mind taking me for a quick ride, I’d really be interested to see what another s55 can do. Thinking the m3 I test drive might have been the problem (some kind of issue with it?) Last edited by Joe240; 03-09-2019 at 09:43 PM.. |
03-09-2019, 09:12 PM | #2 |
4922
Rep 3,805
Something doesn't add up. One thing that the s55 is NOT lacking is power down low. As such, the biggest problem is traction. I'm not sure if the car you drove was the issue or your expecations, but I can tell you that an m240, regardless of mods, should not hold a candle to a stock M3.
EthanEJC199.50 |
03-09-2019, 09:41 PM | #3 |
2925
Rep 1,303
That’s what has me curious. This being a low miles, fairly new m3, I wonder if there was something off about it. I didn’t do manual shift, just let the computer do that stuff, but maybe I didn’t let it stay in it’s power band? Either way, the dead stop run was weird as well. It reminded me of our ‘17 x1 we traded in. Come off the brake, floor it, and it didn’t want to go right away, almost like it was really bad turbo lag. Once the power kicked in, it would pull (for what the b46 could do in a 3600lb vehicle).
03-09-2019, 09:48 PM | #4 |
1973
Rep 2,711
You need to drive with the car in Sport+ Engine and D3 or S3 transmission to activate beast mode. Sounds like you were driving it in Efficient mode, which cuts down on throttle response and timing.
03-09-2019, 09:56 PM | #5 |
4975
Rep 2,268
what kind of one-dimensional test drive was this? you just flooring the throttle in different settings? ever take a turn? ever brake? ever feel the balance and steering of the car?
M cars are not just about straight line speed. Any little freddy in a 2 dolla hooptie can tune their car to have power. It's about the engineering, handling, balance, communication. I've driven the M235 and thought it was a dismal little car. Maybe a 3/10. I've also driven the F80 M3 a few times now and think it's a pretty good car a solid 7/10.
don't read this. too late...
03-09-2019, 10:10 PM | #6 | |
4922
Rep 3,805
03-09-2019, 10:19 PM | #7 |
17485
Rep 10,663
Drives: M4 CS. Former G82, x2 F82, F80
I drove an X1 as a loaner while my M4 was in for servicing, let's just say I don't feel the same way as old Joe here.
03-09-2019, 11:03 PM | #8 |
2925
Rep 1,303
My SA said to hit the m1 button and that was the sport+. However, my understanding is these are adjustable setting so I don’t know how it was configured, for either m1 or m2, so you’re more than likely correct and it was basically the equivalent of ecopro mode of my 240. Might have to go back and mess with the setting and give it another go round. Thanks for mentioning this as I didn’t think about it with 3 other people in the car, all of them talking.
03-09-2019, 11:07 PM | #9 | |
2925
Rep 1,303
The ride was smooth, the car handled fantastically, it was just how the s55 delivered the power that I didn’t enjoy. Even my wife noticed it didn’t deliver power like our 240 and didn’t like that particular aspect of it, liked everything else. |
03-09-2019, 11:11 PM | #10 | |
2925
Rep 1,303
I do think there was an issue with it because after getting on it a bit, I did a little cool down through the parking lot taking the long way around to the spot and it seemed like it was idle/coasting a little odd for a second then went back to normal. Closest I could describe would be low idle and it wanted to die. |
03-10-2019, 05:31 AM | #11 |
Chief Senior Executive Managing VP of Orange Sales
585
Rep 2,581
I would go to a different dealer and test drive another M3, M4, or M2C in Sport+ to get a clear picture and rule out something being wrong with the one you drove. The S55 is a beast.
03-10-2019, 06:07 AM | #12 |
2925
Rep 1,303
I’ve heard great things about the S55 (minus the sch issue when heavily modded). Is there an easy way of putting into sport+ without relying on the m1/2 buttons? Or do I have to set all of that up in iDrive first? I’m going to ask for an extended test drive today and see how things go. If still the same then I’ll make the hour drive to the other dealership.
03-10-2019, 06:21 AM | #13 | |
1996
Rep 1,759
M1/2 buttons are just memory settings and have no bearing on ensuring the engine is in Sport+ If you drive in Efficient mode the engine is sluggish Given that your B58 is already on JB4, I wouldn't expect too much of a difference between the two. Put the JB4 on the S55 then that's day and night! |
03-10-2019, 07:02 AM | #15 |
2925
Rep 1,303
03-10-2019, 07:05 AM | #16 | |
2925
Rep 1,303
Not expecting better performance to my car, but what I experienced was slower from a roll where I was expecting the same level. Sounds like it was in efficient mode during my drive instead of sport+ |
03-10-2019, 09:14 AM | #17 |
115
Rep 288
On m1 you have a late power delivery on 1 and 2 gear. If you place the car on m2 mode with MDM off the car has full power on all gears. But please be careful, there is zero traction on 1-3 gears.
03-10-2019, 11:50 AM | #18 |
1545
Rep 8,970
You can't really do brake hold launches on a DCT Car. That's for torque convertor autos only.
Either use launch control proper or just use gas after coming off the brake. If you give it full gas and have traction fully on it will just cut the power agressively and give it back gently making the car crawl away. Agree you need it in sport or sport + and MDM traction mode on. |
akkando5864.50 |
03-10-2019, 12:09 PM | #19 | |
fuck this field
2192
Rep 2,605
BMW family... for now.
03-10-2019, 01:26 PM | #20 | |
2925
Rep 1,303
I made sure to look up launch control in an m3 and found out how to do it properly in the m3. Also found out about “Smokey Burnout Mode” which also doesn’t include using any brake initially haha. Thank you everyone for the feedback. I do appreciate you guys helping me find where my errors were. I’ll be taking delivery of my m2c in a few weeks it looks like since it just finished production yesterday. |
03-10-2019, 01:43 PM | #21 |
761
Rep 1,015
Drives: Porsche GTS 4.0
I'm curious to read about your 2nd outing with the m3.
03-10-2019, 02:28 PM | #22 |
2865
Rep 3,842
The M235i is very good at accelerating through traffic below 80 mph. The ZF has 8 gears and shifts very fast in Sport+. It isn't a very dramatic transmission but it is really efficient. The M235i N55 has plenty of torque low down but it is lagging at the high end. It is also quite a bit lighter than an M3. That being said, if the M3 has its adjustments set up for sport driving the M235 wouldn't stand a chance.
