03-09-2019, 03:42 PM | #1 |
295
Rep 424
Does the G01 have brake wiping?
Does anyone know if the G01 has automatic brake wiping/drying? I've been poking through the manual and it recommends the following:
"When roads are wet, salted, or in heavy rain, gently press the brake pedal every few miles. Ensure that this action does not endanger other traffic. The heat generated during braking dries brake discs and brake pads and protects them against corrosion. In this way braking efficiency will be available when you need it." I was under the impression that all BMWs automated this process? |
03-09-2019, 03:50 PM | #2 |
129
Rep 276
Seems like it does? Page 5
https://www.rybrookshrewsburybmw.co....resized-pt.pdf also found in the technical manual: Function Dry by applying brake Description Dries the friction surface of the brake disc by cyclically applying the brake pads in rain (no braking perceptible). Last edited by munna; 03-09-2019 at 03:58 PM.. |
XGoober295.00 |
03-09-2019, 04:09 PM | #5 |
295
Rep 424
Thanks - that is what I figured. Wonder why they have that text in the owner's manual then? Just covering their rears or perhaps in extreme wet conditions the auto drying is not as effective?
In any case, I'm glad the automatic system is in place. The Seattle area is not exactly know for dry conditions |
JustChris17489.00 |
03-09-2019, 05:08 PM | #7 | |
295
Rep 424
This is actually what turned me off the Audi Allroad as a possible alternative to the X3. There were reports of the brakes not working well in very wet conditions if they had not been used for a while. Not only that, the car would reportedly move to one side under braking in those circumstances! |
03-10-2019, 03:35 AM | #8 | |
79
Rep 139
XGoober295.00 |
