Bmw 335i makes weird electrical buzzing static noise
03-07-2019, 01:59 PM | #1 |
Rep 30
When i sit in my 335i after turning it off and locking the door about 2 minutes later i hear a strange buzzing staticy humming sound coming from the dash or around there also it 2 minutes after that tbe car sounds like it locks but i never press any buttons it does it on it's own. It makes the lock noise but the car stays locked
03-07-2019, 02:12 PM | #2 |
540
Rep 1,040
Sounds like the fuel pump, which is normal. Is it the same as the sound the car makes when you press the unlock button on your key fob?
2011 E92 335is, Space Grey/Coral Red, 6MT.
RB 2+, Wedge tuned. E85 PI coming soon. |
03-07-2019, 03:54 PM | #3 |
481
Rep 478
Drives: 2009 E93 M3 DCT
Its probably the ventilation motors resetting. Mines makes the same sound. It sounds like a semi truck horn about a block away.
03-07-2019, 06:32 PM | #5 |
481
Rep 478
Yep, it does it on it's own. I believe its resetting to be ready for the next ignition cycle.
03-07-2019, 07:23 PM | #6 |
193
Rep 666
Is does it sound like my (still occurring) issue?
https://www.e90post.com/forums/showthread.php?t=1348547
BMW GT1 (INPA, DIS, WinKFP, ect..), ISTA/P & /D is up and running! PM me if you want to stop by and code your car.
03-07-2019, 07:38 PM | #7 | |
27
Rep 96
Drives: 2011 BMW E92 335i V. Red/SB
When I get into the car but do not start the car I get this buzzing sound from behind the instrument cluster. It is NOT the sound of the fuel pump. It lasts for about 2 - 4 mins and then stops and starts again after a few minutes It sounds like a small motor buzz I do not get any locking sounds Anyone got any ideas? |
03-07-2019, 11:26 PM | #8 |
Art Collector
2427
Rep 3,450
If it’s the flaps moving in the HVAC system, they shouldn’t be making noise for two minutes. It’s normal for them to adjust shortly after you have shut off/locked your car, but that should last only about 20-30 seconds tops.
Not following what you’re referring to about the locking sounds and/or your car being locked. Perhaps you can explain this another way.
When I'm dead, just throw me in the trash.
