03-06-2019, 04:16 PM | #1 |
BMW Client Advisor
3452
Rep 2,504
Drives: 2020 M340i
Z4 Accessories Part Numbers
Driver and passenger front rubber floor mat set 51 47 2 461 171
Floating center caps – set of 4 36 12 2 455 268 Indoor/outdoor car cover 82 15 2 468 464
Contact me for all your BMW needs in the New England area.
jpichardo@tulley.com Top M Client Advisor in New England. |
03-09-2019, 09:29 AM | #3 |
478
Rep 1,250
Drives: 2020 Z4 M40i
03-14-2019, 10:19 AM | #5 | |
Member
385
Rep 236
Drives: Z4 M40i G29
When I purchased the wind deflector kit as an afterfit for my pre-registered E89 in 2016 the part cost me £295 to order from a supplier in Germany. My local dealer wanted £375 to supply the kit and £440 plus VAT to supply and fit it. If ordered as an optional extra on a new car it was £200 at that time. Best approach your dealer to see if he can do something for you before you take delivery of your car. Otherwise you are likely to have to pay through the nose for it. |
06-10-2019, 01:47 PM | #6 |
30
Rep 79
Any luck with the wind deflector? The parts catalogue says retrofit needs 4 parts. The center deflector, the two side pieces that fit inside in the roll hoops as well as the front roll hoop trim covers left and right. Sounds particularly expensive!!
06-10-2019, 02:11 PM | #7 | |
76
Rep 80
Requires the following parts:
In the UK the factory option was £170 whereas the retrofit parts are over £400 plus fitting, so it's a massive difference. I would therefore strongly recommend anyone thinking about ordering a Z4 gets this from the factory! I mistakenly assumed it would be the same price to order as an accessory later on but sadly not. The main issue seems to be the roll hoops are different on cars with the wind deflector from the factory. |
06-10-2019, 03:30 PM | #8 | |
30
Rep 79
06-10-2019, 05:07 PM | #9 | |
76
Rep 80
It’s not the end of the world as I love the car and took a gamble ordering it well before it went on sale, but a slight annoyance anyway! |
06-11-2019, 12:06 PM | #10 | |
478
Rep 1,250
Important when anyone looks at an ordering guide - make sure it’s actually for your market. |
