TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > ConnectedDrive / I-Drive / Navigation Related Discussion > CCC to CIC with DAB upgrade
      03-03-2019, 11:29 AM   #1
Mr.MSport
Drives: BMW e91 330D
I'm Updating my iDrive CCC to CIC with DAB and want to go full OEM spec with the kit including antenna.
After doing a load of research I purchased:
CIC with integrated DAB 65129199906
Updated controller 65829205177
New console trim for controller
trim for CIC deleting Nav CD 51459120979
I have a question in updating the screen and USB and antenna. The most up to date screen is serial 65829193745. It doesn't state which screens are HD and which arent, I was hoping to go for the most up to date that fits into the dash but if the differences are minimal as long as it's high res (looks like they just made the screen non-reflective and deleted the plastic cover).
RealOEM shows the screen as nonexchangeable retrospectively... Is the screen only compatible with certain CIC units or requires specific cable/s?
http://www.realoem.com/bmw/enUS/part...969&series=E91
There seem to be than one type of USB socket for map updates. One has USB and a 3.5mm mini jack (84109237653) and others are just USB. Would I be able to use the USB/Jack and use as a line in?
On the DAB - I understand there are a few options here. A OEM Window antenna that runs to the back window... Has anyone fitted this and can explain how/where it is fitted?
OR the other things I read on this are using the shark fin (don't really want to have to undo the headlining really to do this unless it's an easy upgrade) but it's an option... or a DAB antenna in the bumper which I read is an OEM fitting location?
Real OEM for DAB retrofit http://www.realoem.com/bmw/enUS/show...diagId=65_2440
this looks like the window kit...?
Also refitting the CD changer (I'm old school)
Thanks in advance!
      03-03-2019, 12:30 PM   #2
Nickco43
Nickco43's Avatar
1458
Drives: 08 E92 BMW M3
2008 BMW  [0.00]
Thanks in advance!
The best CIC screens are the E60 ones with the plastic protective cover and the light sensor on it.
Glvoebox USB: 61319167196
Glovebox USB Cable: 61129255716
I am not sure how DAB works. We don't have DAB in North America.
      03-03-2019, 12:42 PM   #3
Mr.MSport
- The best CIC screens are the E60 ones with the plastic protective cover and the light sensor on it.
Thanks, Do you know the part number?
      03-03-2019, 12:58 PM   #4
Nickco43
Nickco43's Avatar
1458
2008 BMW  [0.00]
I normally do not shop with part numbers but this is the number on my E60 display: 65829193745
      03-05-2019, 04:45 AM   #5
Mr.MSport
Diversity antenna looks the way to go for the DAB.
Got 9187647. Hope it fits.
      03-05-2019, 10:30 AM   #6
Mr.MSport
I've realised this is for e92 and wont fit.
I can't even find the serial number for the DAB e91 unit on realoem. I know they are rare though.
Does anyone know if the wiring is the same with the e91/e90/e92 diversity antennas? looks like the wires go into ports in different places but it would be interesting to know if the wiring is the same. Maybe to fit the unit by adapting the antenna case?
      03-13-2019, 12:58 PM   #7
Mr.MSport
Does anyone know how the CIC connected to the antenna on the DAB CIC factory fitted e91?
Did it have to connect to a specific e91 diversity antenna or was the shark fin DAB enabled? I can't see any specific DAB diversity antenna for the e91?
