stereo cuts out
03-24-2006, 07:50 PM | #1 |
Porscheneer
Rep 196
stereo cuts out
I did a search but could not find my problem being discussed. While I am listening to the radio it periodically cuts out. At first I thought it was the station but it happens on all of them. I have just noticed it recently and im not sure how long it has been going on. It is hard to recreate on demand but is very annoying when you’re into the song. The only thing I can think is I recently started using my bluetooth phone, but that should not be affecting it. Any ideas?
03-24-2006, 10:38 PM | #2 |
20
Rep 374
Drives: '05 645Ci Coupe
This seems closest fit to ur problem
SI B65 26 05 Sound System, Cruise, Alarms, Monitors March 2006 Technical Service This Service Information bulletin supersedes S.I. B65 26 05 dated January 2006. designates changes to this revision SUBJECT Audio Switches off Briefly when Listening to FM Stations MODEL E60, E61 (5 Series) with SA 609 CCC-Navigation E63, E64 (6 Series) E90, E91 (3 Series) with SA 609 CCC-Navigation SITUATION The customer states that after setting a radio station preset with RDS (Radio Data System) active, and then deactivating RDS, the audio mutes briefly while the customer is driving. CCC-ANT FC "DACA watchdog reset" is stored. CAUSE CCC (Car Communication Computer) software error. The problem only occurred after the vehicles software was updated using CIP V19.1, V19.2 or V20.x. CCC-ANT hardware defective. PROCEDURE On a customer complaint basis only: Using DIS V45 or later, follow the test plan of the GT1 for CCC-ANT FC "DACA watchdog reset". The test plan could have either of the following results: The test plan result prompts you to program the CCC complete, refer to the following procedure: Update the complete vehicle per SI B09 05 01 (Coding, Individualization, Programming) Procedure B using Progman V21.00.00 (Target Data Status E060-06-03-510, E89x-06-03-510) or higher. After the vehicle software has been updated, turn vehicle off and let vehicle enter sleep mode. The test plan result prompts you to clear the faults and reset the CCC (press rotary knob along with both drive eject buttons simultaneously). Turn vehicle off and let vehicle enter sleep mode. Retest system and if FC DACA occurs again and only with a customer complaint, submit a PuMA case to the Electrical Group Hotline. WARRANTY INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty. |
03-24-2006, 11:36 PM | #3 |
Porscheneer
Rep 196
Cool thanx for the info sounds pretty close except im not turning the RDS off and it does it every so often. So I guess a software update is in order.
Thanx a bunch
03-25-2006, 05:13 PM | #5 | |
20
Rep 374
03-25-2006, 06:48 PM | #6 |
Porscheneer
Rep 196
thanx for the tip I will give it a try. thanx guys
