Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > 5mm spacer and hub centric ring
      03-02-2019, 06:42 PM   #1
C408
Drives: 2006 325i 6 speed
so I was able to fit a 5mm spacer as well as the hub centric ring on the hub but theres a bit of overhang. I've got at least 5mm or so of the ring on the hub but with a bit of overhang. havent been able to drive the car yet since I'm doing the headlights but what's the take on that? should I be fine or are there some implications of not having the ring butted up against the hub firmly I'm not thinking about? [IMG]undefined[/IMG][IMG]undefined[/IMG]
Low > Fast
      03-02-2019, 10:06 PM   #2
C408
bump..... anyone see anything wrong with that not sitting completely flush. I'm aware I could possibly get a little wheel vibration but my thinking is its butted flush against the spacer so it should probably be fine. wheres that super critical person to tell me the 1% chance my wheel could explode or something lol.
Low > Fast
      03-03-2019, 02:14 PM   #3
snedanator
97
Drives: e93 335i le mans blue
Theoretically thinking there shouldn't be a problem as the ring is only to centre the wheel and the face of the inside of the wheel will be flush against the spacer and the bolts will hold it onto that face. So it should be fine. Can I ask why the ring is needed? Is it cause the bore of the alloy wheel is different from the original hub ring?
      03-03-2019, 02:52 PM   #4
C408
correct, it just fills the gap from an aftermarket hub bore to sit properly on the hub. eliminates wheel wobble while driving at high speed. I didnt think it would be an issue either since theres plenty of it on there and its flush against the spacer but I'm new to bmw cars and they're far finickier than hondas so always best to measure twice and cut once.
Low > Fast
      03-07-2019, 07:16 AM   #5
dublin14
dublin14's Avatar
148
Drives: Bmw 335i- F150 FX4- Audi A4
What year is this on? I would like 5mm to fill out the rear myself on my 08 E92.
      06-21-2019, 04:26 PM   #6
C408
it's on a 2006 325i sedan.
Low > Fast
      06-26-2019, 10:13 AM   #7
Volasko
Volasko's Avatar
705
Drives: 06 330i E90, 18 530xe G30
I asked a similar question when I was adding 8mm spacers, which did not have a ring extension (wouldn't work) and I was told the following points:
The ring is meant to help center the wheel, not take any loading during driving. The loading is handled by the bolts/studs. Now because the ring isn't centering the wheel when installing it was suggested that when torquing the wheel to slowly creep up to the torque value, ie) start at 40 lb/ft, then 60, the 88 or whatever your spec is. This will help ensure the tapered bolts are properly centering the wheel and you don't clamp it down off-center by accident.
      06-26-2019, 01:09 PM   #8
FCobra94
Guest
n/a
Drives:
*rubs eyes and reads all replies over again*
wtf are half you guys even talkin about?
Since when did BMW move from a HUB centric design to LUG centric design? Of course the hub centric rings are necessary because the hub bares the weight of the vehicle! Hence the term HUB CENTRIC.
OP since you have a very early E90 (one of the first) what I think might be happening here is that the hub is lip on your car is longer than on most other (newer) cars. Here's a perfect example:
https://www.e90post.com/forums/showthread.php?t=602582
It's also why Turner makes this disclaimer:
10mm Fitment Note: You must be very careful when fitting 10mm spacers to any BMW. Since the depth of the hubcentric lip will vary, you risk bottoming out of the spacer before it sits flush with the hub. This will leave a gap between the spacer and the hub, seriously compromising the strength of the spacer. The lip on the car may need to be shaved down so the 10mm spacer will fit flush on the rotor hat.
Long story short, I would measure it to be sure. Having "overhang" sounds like a not so smart idea, especially on wheels which are expected to turn your vehicle.
      06-27-2019, 06:18 AM   #9
Tr1ppy
Tr1ppy's Avatar
36
Drives: E93 330i M Sport
I always thought with such a small spacer (5mm) that a hub-centric ring is not required.
H&R offer 5mm spacers without the hubcentric ring and they call it a "DR system" spacer whatever that means.
      06-04-2020, 09:52 PM   #10
pennychow
Drives: bmw e90
is there any 5mm H&R spacer for BMW?
      06-05-2020, 06:15 AM   #11
Tr1ppy
Tr1ppy's Avatar
36
Sold out at the moment but can be bought here as well as other stores
https://www.demon-tweeks.com/h-r-pai...9e0c09fdc50cfe
      06-05-2020, 11:36 AM   #12
nsjames
2440
Drives: 08 328xi Touring
ST makes 5mm spacers with hub centric ring inserts.
      06-07-2020, 10:32 PM   #13
pennychow
Drives: bmw e90
how can it be possible....
just read their official webpage.. only 10mm or above have extended hub centric ring ..
      06-09-2020, 10:09 AM   #14
nsjames
2440
you're correct, I thought the plastic ring inserts they were using also had a lip.
