03-02-2019, 09:54 AM | #1 |
123
Rep 353
What is the biggest spacer on OEM wheels and tires someone here has installed?
Rephrasing a previous post, I believe the max size this car allows is 17.5mm at the front and 15mm in the back?
Can a vendor or someone here confirm what the biggest is? I'd like to know so that I can figure out what the max tire width is that I can run on this car by sticking 11m spacers on the front and back. Thinking 285/295 or 295 all around. Last edited by BigMacSmallFries; 03-05-2019 at 11:14 AM.. |
03-05-2019, 11:31 AM | #3 |
12966
Rep 18,713
It would depends on are you lowering it or not?
Lowered with M550 spring, max 18mm front, 11mm or 12mm rear. Tire wise, be careful on the front and rear ratio since it is AWD. You don't want to damage the transfer case.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS iSweep RaceChip Sterckenn AutoTecknic Akrapovic Vossen Wheels Eventuri Active Autowerke KW H&R Ohlins Remus and more... |
03-05-2019, 03:23 PM | #4 |
123
Rep 353
Hey, no lowering is being done. Do you think its 18 and 15 with the stock suspension? I imagine a square setup (since winter tire packages available with this) or a 285/295 setup shouldnt cause any harm.
03-05-2019, 03:32 PM | #5 |
12966
Rep 18,713
If you are not lowered, I would do 11 all around with 285 square.
03-06-2019, 02:40 PM | #6 |
123
Rep 353
Do you think I can do 285/35/20 Sport Cup 2's all around with 11's everywhere?
Keep in mind Sport cup 2s are +1s and so 285s are really 295s width with the profile of a 285. Thanks! |
03-06-2019, 10:21 PM | #7 | |
12966
Rep 18,713
May need to go lower than 11mm on the rear then, or maybe none.
03-08-2019, 11:20 AM | #8 |
123
Rep 353
Will try 12mm front, 11mm rear with these 285s (actually 295) and see what happens. Thanks!
r33_RGSport12966.00 |
03-08-2019, 01:57 PM | #9 | |
12966
Rep 18,713
Let me know if you need quotes. I have them in stock.
03-08-2019, 10:46 PM | #10 |
123
Rep 353
Thanks, I already have the spacers.
03-08-2019, 11:07 PM | #11 |
12966
Rep 18,713
Good. Post some pictures.
