Extreme Powerhouse
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > What Mod to make
      03-24-2006, 05:46 PM   #1
england1987
24
Drives: Z4 M coupe
2006 Z4 M Coupe  [7.50]
What Mod to make
I'm trying to get ahead of the game. I am trying to find out what the best handling mods are. Since most modern cars are engineered to understeer from the factory, what will decreace this dendency. I was thinking that changing the rear sway bar to H&R or Eibach. Or maybe changing the springs. What about adding a strut tower brace.
Any imput is welcome
      03-24-2006, 05:51 PM   #2
ward
155
Drives: F
springs and sways, and while you're in there new shorter shocks too
the strut brace won't change handling tendancies
      03-24-2006, 05:55 PM   #3
Squawks
One of my two dachshunds:
Squawks's Avatar
53
Drives: B6 A4 3.0 Quattro
If you are hardcore, change the cambers. Roll-cage. Strip the car down. Buy an STi or EVO.
I'm sorry about my outlandish behavior - there's too much blood in my alcohol system.
      03-24-2006, 06:00 PM   #4
england1987
24
Drives: Z4 M coupe
I am not that hardcore. I want street car that can hold its own on an autocross and spirited backroad driving.
      03-24-2006, 06:11 PM   #5
Squawks
Squawks's Avatar
53
Well, the first rule of handling is to buy the best R-compound tires you can.
Increase your front tire pressures and reduce rear pressures (in 2.5 increments) if you want more oversteer and less understeer.
Likewise, if you increase the width of the front wheels while decreasing the rear, you also increase oversteer.
If you buy new dampers, decrease the damping forces for the fronts and increase the rears.
Other things you can do is get springs with different spring rates for the fronts and the rears (soft for fronts, stiff for rears). Suspension bushings also can help (stiff fronts, soft rears) and like Ward said, a sway-bars help as well (soft fronts, stiff rears).
Of course, use common sense and if you try to do all of this in one install, you may eventually get excessive oversteer.
EDIT: Anything opposite would conform to the opposite (e.g. increase understeer while decreasing oversteer).
