02-26-2019, 05:58 AM | #1 |
16
Rep 38
Automatic Headlights: Do you use it often?
Hi all,
So, this past weekend, twice (once when going and once when coming back from somewhere..) I had cars going by me in the opposite direction honk for what I thought it was no reason until it hit me. They were probably blinded by my beams being on high, rather than low, or something in between. I have been trying to drive at night always with the Automatic Headlights feature on. On dark roads and not a lot of movement is great, goes up, goes down, one side, other side, seems to work well. However, I have also noticed that when on a small road where one side goes one way and the other side the other way, they do not work well all the time, and or, something like I mentioned above happens, people honk/complains. How can I properly test if this is working properly? I mean, its nice to leave it on all times, but, if its causing trouble for other cars, then I would go back to old style where I turn on/off on demand instead of automatically. Suggestions, Ideas? Anyone uses it? |
02-26-2019, 07:45 AM | #2 |
86
Rep 61
I live in a "country" like area where the majority of the roads are very dark, and the automatic high beams are very useful. I use them all the time. However, even when not using I have had people shine their brights and/or honk because they believed I was shining high beams in their direction. IMO, the standard headlights alone are VERY bright compared to most cars. I'd continue using if you need to for the sake of your own safety.
02-26-2019, 08:56 AM | #3 |
44
Rep 98
Are you referring to the automatic on/off setting on the headlight switch or the automatic high/low beam button on the end of the turn signal stalk? My car has both. I leave the headlight switch on the automatic setting and it is very good about switching over from daytime running lights to headlights at dusk and dawn. I also use the automatic high/low beam setting and it works very well, but is occasionally slower than I mioght be in turning off the high beam, because I can see an oncoming car's headlights around a corner. Also it will sometimes go from high beam to low beam due to street lighting. But overall, it is much more consistent than I am. I do wish there was a way to program my car so that the automatic high/low beam was always activated unless I turned it off with the button. One other peculiar thing I noticed is that we have both a X3 30i and a X3 M40i, both are 2019 models and have all the same options and packages. The X3 30i does not have the automatic high/low beam switch on the end of the turn signal stalk though, while the X3 M40i does.
MechX3M40i1006.00 |
02-26-2019, 09:00 AM | #4 |
16
Rep 38
02-26-2019, 09:08 AM | #5 | |
1006
Rep 1,727
My auto high beam works perfectly during my test driving in rural part of the suburb with no issue. |
Dutch157686.00 |
02-26-2019, 10:23 AM | #6 |
151
Rep 188
M40i has Icon Adaptive LED as standard - it’s optional on other models I believe.
I’m very impressed by the way the high beam comes on automatically according to road and lighting conditions. And by the way the beam adjusts to light up around a vehicle that is in front! The lights also light up around a corner - I think the system switches on the fog lights. Great for city driving in the dark to better seen pedestrians crossing at the junction you’re turning in to. The lights actually move as you turn your steering wheel. You can see this better by being stationary and having your lights aimed at a wall. When you turn your steering wheel, you will see the lights angle towards the direction you steer to. |
02-26-2019, 10:29 AM | #8 |
151
Rep 188
Better technical vid (but the previous video was in a G01!)
MechX3M40i1006.00 |
02-26-2019, 12:07 PM | #9 | ||
127
Rep 304
Drives: 2018 X3 i30xdrive
MechX3M40i1006.00 |
02-26-2019, 01:38 PM | #10 | |
Exalted Tire Scorcher
35
Rep 91
02-26-2019, 02:04 PM | #11 |
151
Rep 188
Wow... did not know that! Does US also not get the Audi equivalent either then?!
02-26-2019, 02:08 PM | #12 |
35
Rep 91
The new regulations that would allow adaptive in the US were proposed by the NHTSA in Oct 2018 but I don't know when they would come in to force. I doubt it would be that quick so I would say no to the Audi equivalent.
02-26-2019, 02:33 PM | #13 | |
153
Rep 372
Drives: 2019 X3 M40i
I have not had anyone flash or honk at me since I had them coded about 6 months ago. |
02-26-2019, 02:53 PM | #14 | |
35
Rep 91
Yeah, it is amazing the rules are that far behind despite being lobbied by the manufacturers for quite a few years now. The segmented headlight systems are stunningly good and the ICON adaptive is way better than anything we have now. |
MechX3M40i1006.00 |
02-26-2019, 03:00 PM | #15 | |
153
Rep 372
02-26-2019, 04:43 PM | #16 |
551
Rep 980
There’s a difference between ‘High Beam Assist’ and ‘Adaptive’. I use my adaptive most of the time and have never had anyone flash me yet.
Speedbird1101.00 |
02-26-2019, 10:16 PM | #17 |
Head Idiot
251
Rep 551
The automatic high beams are iffy for me. It seems to work decently if you're on a road where the two directions are separated by a painted line. It's iffy and can blind drivers if you're on a road with a wide median (say, 10+feet/3+meters). The separated directions seem to confuse the auto high beams occasionally. It's even worse if the road has a slight curve to it.
SROC31702.00 |
02-26-2019, 10:29 PM | #18 |
The limit of adhesion is my home.
1702
Rep 3,778
I live in LA and I drive mostly in the city streets....once in a while go out of town. Had the Adaptive EURO lights on my M4. They worked amazing, but RARELY ever used it. I didn't opt for the Adaptive LEDs on my X3. Don't regret it at all. Light-Cast is perfect. Fog lights are awesome too on our cars.
2019 X3 xDrive30i Glacier Silver | Cognac w/ Fine Cove | MSport | Premium | Dynamic Handling PKG | Drive Assist | HK w/ Bavsound Upgrade |
02-27-2019, 04:37 AM | #19 |
926
Rep 2,046
Drives: X3 G01 30i xDrive
I mainly use adaptive low beams. When I user the AHB (automatic high beams) I've got nor honk/flash from other drivers. Needles to say, that AHB are using selective beam, so if no car in front of you but one in opposite direction, the high beam stays on on your direction of travel.
Once a X3 was opposite to me, it wasn't dark but it was late, and the lights were quite bright from my view. People are not used to this, like there were not used to halogens when they were introduced. Also the higher position of the lights in opposite of a sedan/hatchback/wagon can cause others to be little dazzled by them.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
02-27-2019, 05:12 AM | #20 | |
Idiot-in-chief
31
Rep 218
As it can be done on the F25, I'd be very surprised if it can't be done on the G01 Mine is a UK model with ICON adaptive LEDs (anti-dazzle enabled from factory) and, according to my records, the coding changes required were: FRM module - 3050 -- FLA_AUTO_AKTIV -> automatisch - 3050 -- FLA_VERBAUT -> aktiv HU_NBT module - 3000 -- HIGH_BEAM_ASSISTANT -> aktiv KAFAS2 module - 3050 -- FLA_ON_OFF -> aktiv
X3 F25 LCI 30d M Sport
Alpina Roadster S |
02-27-2019, 08:25 AM | #21 |
16
Rep 38
I guess that is the case, as indeed are curvy roads that go up and down indeed where this happened. Thanks everyone. And yes, its pretty cool how it goes up, low, left, right, on, off by itself... I really enjoy it...
02-27-2019, 11:10 AM | #22 |
133
Rep 186
Drives: X3 M40i Alpine White
I absolutely love this feature, but i have found it can sometimes be a bit slow with turning off when oncoming traffic is detected!
I wish it would come on automatically without me having to enable the function via the left stalk on every trip |
Tags |
automatic headlights |
