02-18-2019, 10:15 PM | #1 |
170
Rep 445
Drives: 2018 X3 M40i
Location: Milky Way, Earth, North America, Arizona more specifically.
X3 M40i factory alignment specs... anyone?
Like the title says, I’ve scoured the interwebs and can’t seem to find them at all... anyone know the factory alignment specs for our cars?
Any help is much appreciated 😉!
"Since light travels faster than sound, some people appear bright until you hear them speak". |
02-19-2019, 10:56 PM | #3 |
170
Rep 445
I have the Adaptive, but I doubt the alignment specs are different for either, you think? Either way, if can’t seem to locate them anywhere so if you can share any, please do.
02-20-2019, 01:14 AM | #4 |
35
Rep 14
I did a alignment after I lowered my M40i, this is the paper i got.
Before and after the alignment. |
MechX3M40i1006.00 |
02-20-2019, 05:48 PM | #6 |
170
Rep 445
02-20-2019, 06:46 PM | #7 |
1457
Rep 3,933
Wheel alignment of G01 M40i front axle all-wheel drive vehicle
* To minimise adjustment errors (measuring inaccuracies), use a narrower tolerance for the toe/camber adjustment! Toe difference front axle = criterion for steering wheel inclination Total toe-in 0° 10' +/- 10' Total toe-in adjustment* 0° 10' +/-4' Toe difference on single wheel between left/right max. 12' Camber (difference between left/right max. 30') -0° 50' +/-30' Camber adjustment* -0° 50' +/-25' Toe difference angle (difference between left and right) max. 20' Castor angle (difference between left and right) max. 30' Front wheel offset 0° +/-15' Largest steering angle on inner cornering wheel Approx. 38° 14' Largest steering angle on outer cornering wheel Approx. 32° 08' Wheel alignment of G01 M40i rear axle, all-wheel drive vehicle * To minimise adjustment errors (measuring inaccuracies), use a narrower tolerance for the toe/camber adjustment! Total toe-in 0° 08' +/-12' Total toe-in adjustment* 0° 08' +/-4' Toe difference on single wheel between left/right max. 12' Camber (difference between left/right max. 30') -1° 30' +/-25' Camber adjustment* -1° 30' +/-05' Geometrical driving axis 0° +/- 12' |
MechX3M40i1006.00 |
02-21-2019, 07:16 PM | #10 |
626
Rep 1,044
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
Your camber settings front and rear are pretty aggressive. Was it set up for handling?
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131 2021 SQ5 |
