02-16-2019, 12:00 PM | #1 |
30
Rep 65
Drives: 2019 X3 M40i
Hey everyone. I don't have an adaptive suspension on my M40i and so I was thinking about options to enhance the suspension (lowering, air etc). My goal is to retain the sport quality while adding some level of forgiveness. I also want to lower it ever so slightly as others in the forum have done.
So what does is the m sport suspension made of that can't already be had by using aftermarket components? And will adding aftermarket components actually degrade the suspension (because the M suspension is considered good already) or are aftermarket components (such as springs by H&M or Schnitzer) generally considered upgrades over stock M? Someone school me, I'm new to this. Thx in advance.
Proud papa of a 2019 X3 M40i
02-16-2019, 12:18 PM | #2 |
6659
Rep 15,858
It is the "adding some level of forgiveness" comment, where it is harder to tune the stock M-sport suspension with aftermarket parts.
It is why users go the adaptive route, as that does allow a softer mode to the suspension. Lowering typically stiffens the suspension, due to less spring travel, usually a higher spring rate. There may be some progressive springs which could give you what you want. |
02-16-2019, 03:05 PM | #4 | |
6659
Rep 15,858
RFTs won't help the sensitivities. What wheel size is the OP running? Could they be down-sized as well? Get more comfort from the wheel/tire choice. May be the simplest and immediate solution. |
02-17-2019, 11:27 AM | #6 |
155
Rep 230
Spare tire on roof...
2018 GO1 X3 M40i Alpine White
2018 Acura RDX Tech Pearl White 2016 Tundra TRD Pro (sold) 2013 Boss 302 Race Red (sold) |
02-17-2019, 01:00 PM | #7 |
29
Rep 27
02-17-2019, 07:04 PM | #8 |
1457
Rep 3,933
02-18-2019, 07:19 AM | #10 |
97
Rep 271
I dont have a spare wheel just some gunk and a pump that is supposed to be squirted into the flat, I do have runflats though but theyre there to get you safely to the roadside not get you home, BMW assistance or a Roadside Recovery service should get you home or you could call a mobile tyre fitter
02-18-2019, 06:21 PM | #11 | ||
30
Rep 65
02-18-2019, 06:23 PM | #12 | |||||
30
Rep 65
02-18-2019, 07:44 PM | #13 |
151
Rep 301
Drives: 2019 BMW X3 M40i - Sold
A runflat, in theory, MUST be firmer than an equivalent non-runflat as the tires needs a firm structure to hold the shape of a tire without air. I have experience swapping low-profile/sporty factory runflats (ContiSportContact 5) for non runflats (Michelin Pilot Sport 4S) of same size. The difference was significant it terms of smoothness. I would say a good non-runflat will absorb bumps better than an equivalent runflat.
2023 BMW X7 40i // Mineral White // Silverstone Sensafin // MSport Pro + Performance Enhanced
2020 BMW X6 M50i // Alpine White // Mocha Vernasca // Performance Enhanced 2019 BMW X3 M40i // Alpine White // Cognac Vernasca - SOLD |
