Aftermarket valve cover
02-13-2019, 02:11 PM | #1 |
Rep 60
My wife's e92 325i has developed a leak at the valve cover. Seeing BMW covers are prone to leaking and cost nearly £400, has anyone used a aftermarket valve cover. They cost a 1/3 of the BMW part. Any opinions would be appreciated.
02-13-2019, 03:53 PM | #2 |
623
Rep 3,198
Drives: E92 325i MSport Coupe
Unless you can tell that the cover itself is cracked, then it's most likely just the cover gasket that's failed. These harden over time, particularly if the oil isn't changed very frequently. Loads of 'how to' videos on YouTube...
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; 3 x chassis braces; diff brace; N53 V-brace; 034 subframe inserts; BMS clutch stop; BMS CDV; RE g/box mounts; Delrin shift bushes; Saikoumichi OCC; Cyba scoops; BMW Perf Exhaust; HEL s/steel brake hoses; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; LED side repeaters; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
whyzee1251690.50 |
