02-11-2019, 10:36 AM | #1 |
43
Rep 66
2019 X3 Iso Fix Cover Replacement
Have a 2019 X3. While installing a car seat broke the ISOFix cover. Dealer wants $180.00 Part is work $60.00 in Canada. Think should be easy to replace but can't find instructions/ drawing. Thanks in advance.
02-11-2019, 11:44 AM | #2 |
Freude am Fahren
108
Rep 278
Current: 18 X3 xDrive30i Past: 03 530i Sport | 06 330ci ZHP | 14 X1 xDrive35i M-Sport | 11 328i M-Sport | 98 M Roadster |
02-11-2019, 12:48 PM | #4 |
Freude am Fahren
108
Rep 278
Newtis.info has all the latest BMW technical info:
https://www.newtis.info/tisv2/a/en/g...ity/1VncBUkWYx
02-11-2019, 01:19 PM | #5 |
43
Rep 66
Thanks, doe it mean that I have to follow all the instructions to replace the ISOFix or by just lifting the seats should be able to replace the ISOFix on passenger rear door site. The pictures are very helpful and wondering if there is a locking system for the ISOFix cover.
02-11-2019, 01:39 PM | #6 | |
Freude am Fahren
108
Rep 278
I've R&R'd many a BMW lower backseat and they were very easy to do, and looking at the newtis info it doesn't look like they changed much if anything: Pull up on the front edge, it unclips, then pull forward & lift until it is out. Then you should be able to see the ISOFIX and go from there......
02-22-2019, 12:02 PM | #7 | ||
43
Rep 66
02-22-2019, 03:19 PM | #8 |
10995
Rep 32,881
02-23-2019, 06:23 PM | #9 |
43
Rep 66
No I did not take the complete seat out. Lot of wires attached
02-23-2019, 07:10 PM | #10 |
Rep 263
They just pop on and off. Mine broke too and showed my dealer. They removed the broken ones and gave me new ones to pop in when my daughter is out of the car seat since the new ones would probably just break again with a tight car seat install.
02-23-2019, 09:30 PM | #11 |
783
Rep 911
Drives: 2020 X3 M40i
$180!! Makes me angry just hearing it.
BMW Dealers are so harsh. BMW swapped out my car after having issues that couldn't seemingly be fixed. I forgot to switch out my K&N filter. I asked dealer how much to change / swap air filters. I thought they would burn me with a $50 charge.. Nope. $250. Utterly ridiculous. 10 min work, max. I know they're in business to make money, but the old adage, "You can shear a sheep for life, but you can only skin him once," comes to mind.
• 2020 BMW X3 M40i Graphite : ZDA/ZDB/ZPX/718M/2VF/2T4/3KA/3AC/688/6NW/3AC
02-28-2019, 08:48 AM | #12 |
43
Rep 66
Cant get the ISOfix cover off the seat. Anyone has a picture of how it attaches so I can attempt to take the cover off. Also, can't get the middle seat buckle to come through the seat. Any ideas. Thanks in advance. Cheers
07-29-2020, 02:16 AM | #13 |
795
Rep 1,959
Are they really that shitty? I would have thought they were made out of metal or something for that MSRP. How can they justify not replacing them under warranty if just using them correctly results in breaking?
06-22-2021, 07:15 AM | #14 |
Rep 32
I will dig this up a little beat. Since newtis.com is closed I can't look up how to replace the isofix cover. Hence looking for your advice
1. Do I need to lift/take off the bottom part of rear seats? If so how can I do it? Should I grab it by front front part and pull it up? Or should I grab it and pull it forward (I mean to front of the car). 2. I notice that main part that is holding the isofix cover is the 'hook' on the bottom part of it. How to lift it and remove it? I've search around and there's no clear answer for this and hence it is common issue that would be great to figure it out and leave it here for others |
06-22-2021, 07:35 AM | #15 |
926
Rep 2,046
Drives: X3 G01 30i xDrive
Didn't try it myself, but it's waiting for me. Also broke the isofix cover, stupid me was pulling it out, not in.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
06-22-2021, 08:13 AM | #16 | ||
Rep 13
If you buy the replacement part you will see how it fits. No need to remove seat. Pull from bottom as part pivots on a bar at the top. Tab at bottom may snap. Replacement just pushes in. |
06-22-2021, 09:12 AM | #17 | ||
Rep 32
Yeap, that what I thought - to use a bit of a strenght to pull it back regardless if the bottom part snaps. Good to have it confirmed now Thanks a lot. |
06-22-2021, 12:01 PM | #18 |
795
Rep 1,959
06-22-2021, 12:05 PM | #19 | ||
Rep 13
06-23-2021, 04:51 AM | #21 |
Rep 32
I just ordered new cover. We will see about that quality.
However to be honest - i am not concerned about bottom tab. On the other side I have one with broken bottom tab and it sits very good The problem with mine is these hanging part on a hinge/spring. That's the reason I am replacing it. Will let you know where my part comes in. |
Alias1431795.00 |
