BMW M5 F90 (2018+) General Forums Mechanical Maintenance: Break-in | Oil & Fluids | Servicing | TSB | Recalls    Fuel Injector Failure after 4 days
View Poll Results: If you had this car would...
Keep it? 10 90.91%
Return it? 1 9.09%
Voters: 11. You may not vote on this poll
      02-08-2019, 01:00 PM   #1
lgreenlee
Drives: 2019 M5 Competition
Angry Fuel Injector Failure after 4 days
I just picked up my new 2019 M5 Comp. on Monday. After about 80 miles of driving, the drive train failure light popped up. The engine was rough at idle and in park as well as under power.
Limped it to the dealer and they took a look at it.
Apparently cylinder 4's fuel injector is shot.
I'm not real happy for obvious reasons - does anyone have a similar experience?
I'm on the fence for pushing for a replacement vehicle.
Thoughts, wisdom and advice is welcome!
Thanks!
      02-08-2019, 02:45 PM   #2
Ever34
325
Drives: F90 M5
Thanks!
Things fail. I think pushing for a replacement is a little extreme. In other words shit happens. What's important is how they deal with it.
      02-08-2019, 02:49 PM   #3
Pimpsy
420
Drives: 2019 M5C
I agree that a replacement vehicle is probably a bit extreme at this point. Hopefully they give you a nice loaner vehicle and fix it right away.
I would ask them to throw in a little M swag though.
Retired 2016 BMW 550i xDrive MSport | 2013 BMW 550i xDrive MSport | 2012 BMW 535i xDrive | 1988 BMW 325ic | 1984 BMW 318i
      02-08-2019, 03:44 PM   #4
Miko M
///M
Miko M's Avatar
6652
Drives: 2020 M2C. 2020 X3M
Thanks!
Car is under warranty and I wouldn't worry to much.
No car is bulletproof!!!
Could you share the code and error message?
Life is too short...enjoy your life
///M
      02-08-2019, 04:22 PM   #5
lgreenlee
Thanks for the comments! I've not had any fuel injectors go bad so I don't know much about the potential effects later on which was my concern.
      02-10-2019, 10:52 AM   #6
ztx84
185
Drives: 2022 M4 Competition Xdrive
Shoudn't have any adverse effects I wouldn't have thought - its just one of those things. Anything mechanical can break... As a previous poster said, it is how your garage deals with it that is most important.
      12-05-2023, 09:31 PM   #7
Mcfly58
Mcfly58's Avatar
Drives: Bmw m5 comp
Picked up a used 2020 M5 comp with 30k miles...1 month in, injector failure...2 months in
Injector failure...whats next?
      12-05-2023, 10:36 PM   #8
Stlthnmrdrd
1-800-STOCKAF
157
Drives: G30 520i (Stock)
Coolant leak and then blown motor
F30 320i Stock
hookson82.00
      12-05-2023, 10:45 PM   #9
Mcfly58
Mcfly58's Avatar
Drives: Bmw m5 comp
I did see some posts about a coolant overflow Reservoir leaking on injectors, dealership repeatedly told no leaks found!
      12-06-2023, 07:21 AM   #10
pbonsalb
5227
Drives: 18 F90 M5, 99 E36 M3 Turbo
Could be damage from past leaks and someone subsequently replaced the tank and cleaned up the evidence before selling the car.
      12-07-2023, 06:44 PM   #11
916_M5
IG: @M5RCY_
916_M5's Avatar
364
Drives: BMW F90 M5
Something similar happened to me.
Had to replace all injectors, and coils and LPFP on the driver side.
All warrantied.
Back to normal
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off
Dura-Coating - code: M5RCY for 20% off
m5post
