BMW X5
      02-05-2019, 12:05 AM   #1
Dcinlv
Dcinlv's Avatar
31
Drives: 2017 G30 M sport
22" tire pressures
Those of you with the 22's, what tire pressures are you using front & rear? The suggested in iDrive feel overinflated.
      02-05-2019, 07:48 AM   #2
AndroidRobot
AndroidRobot's Avatar
4326
Drives: 2022 Porsche Boxster GTS
  [0.00]
2022 Porsche Boxste ...  [0.00]
check your door plate
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order)
2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD)
2018 BMW M2 Mineral Grey(SOLD)
2019 BMW X5 50i Carbon Black/Tartufo (SOLD)
      09-29-2020, 06:12 PM   #3
EUPremier
Ireland
65
Drives: 2020 X5 M50d
Would like to know too... my experience of using the door plate (in my past BMWs) pressures is premature tyre wear.
Adding some PSI seems to help.
I'm running an M50d on 315/30/22 rear & 275/35/22 front. Both are non-RFT.
Based in Ireland so average annual ambient temp is probably around 10C.
Usually drive alone with little or no luggage.
Any recommendations for similar conditions & weight?
Currently driving 2016 F10 M5 & 2017 G11 730d.
Note: Taxes on vehicles in Ireland are bananas!
Previously
2019 G05 X5 M50D, 2016 F36 430d, 2012 F10 520d, 2006 E60 M5, 2005 E60 530D
      09-29-2020, 07:22 PM   #4
VTENGR
1045
Drives: 2020 X5 M50i
iDrive is telling me 42 in the fronts and 47 in the back so that's what I'm running. 22" Contis
      09-29-2020, 07:29 PM   #5
bmui1561
33
Drives: G05- 2021 BMW X5 x40i M-Sport
Same here (42PSI Front, 47PSI Rear, 22" Contis as well
      09-30-2020, 03:05 AM   #6
Gtz1wickedest
Gtz1wickedest's Avatar
647
Drives: 2020 BMW X5
I'm at 39 fronts and 42 rear for a little more comfort no issues so far 8 months on NYC roads
      09-30-2020, 04:49 AM   #7
bmui1561
33
I'll be throwing on 20" wheels and blizzaks for winter driving (first winter with this setup) any ideas on tire pressure? Will iDrive throw an error as I'm guessing the tire pressure on the 20" wheels will be different than the 22s?
      09-30-2020, 02:12 PM   #8
scotchy
210
You can go into iDrive and select 20" under winter tires.
      10-16-2020, 02:07 PM   #9
TORGUE
24
Drives: BMW 430i
im running 22" and i drive tell me 33psi
      10-17-2020, 03:08 PM   #10
Pro55
110
Drives: BMW X5 G05 30d
I started of a year ago running the door plate psi and started getting premature sidewall wear on the contis. I upped it about 6 months ago by 5 psi from the low load figure and the wear is so much more even now. Got about 15000 miles on them now and measured them last week at 5 mm tread so still going strong. Pleased overall with them.
      10-20-2020, 08:48 AM   #11
imyb
53
Drives: BMW X5 M50D
seems to be some difference between peoples readings:
fronts (275/35 R22) currently range between 33-34psi
rears (315/30 R22) currently range between 34-36psi
which seems to match the label on the car (attached below).
G05 X5 M50D - Carbon Black - Tech Pack - Comfort Pack - Sky Lounge - Individual Merino Leather
      10-20-2020, 01:47 PM   #12
scotchy
210
Guessing that's for an X5M? It's got mixed front and rear size there of 21/22"
Edit... I said it backwards but I think you know what I mean.
      10-22-2020, 04:26 AM   #13
imyb
53
Drives: BMW X5 M50D
It's for the M50D which has 22s front and back, not the mix like the X5M.
      10-22-2020, 08:19 AM   #14
Addbuyer
Addbuyer's Avatar
832
Drives: X3MC
Run flats here so no air required, solid rubber right. Its the way to go
Search this Thread:
Advanced Search
xbimmers
