HELP: Right Rear Break Light Malfunctioned?
07-21-2008, 12:57 PM | #1 |
66
Rep 653
hmm... The right rear break light message came on yesterday after my carwash. So I checked the rear lights and not sure if everything is fine... I am not sure if the very right (circled in black) part the the tail light is supposed to light up when hitting the break? Both my left and right break lights look the same although the computer only tells me the right one is not working. Anyone experienced this? If nothing is wrong... how can I reset the error msg?
07-21-2008, 01:01 PM | #2 |
167
Rep 7,433
By going to the dealer
-Brian
2X 2006 BMW 325i [Electric Red & Mystic Blue] | ZPP | V1 | Rear Fogs | M3 Lip Spoiler | EAS RemoteKey | BMS Powerbox | Projector90 Headlights w/ LED AE | LED plate lights | OEM Blacklines http://www.tech-shine.com |
07-21-2008, 01:06 PM | #4 |
15
Rep 292
Why circle the left one? Anyway go to the dealer.
2011 X3 xDrive35i F25 (CPO) Space Grey/Black Leather, Packages: Premium, Cold Weather, BMW Apps, Sirius and Technology. BMW CCA Member (WindyCity Chapter). Former cars: 06 750i E65 (CPO) 07 E90 335i (bought used but had problematic iDrive so sold it to get 7-series)
07-21-2008, 01:09 PM | #5 |
14
Rep 77
Go to dealership
Yeah take it to the dealership.
Mine gave me the same error couple month back (once for brake light and once for backup light) I took it to the dealership, they ended up replacing the socket. I think the SA told me there was a bulleting recall for it. |
07-21-2008, 01:12 PM | #6 | |
66
Rep 653
07-21-2008, 02:21 PM | #8 |
153
Rep 5,780
Pop the cover off in the trunk, pull out the assembly, pull out all bulbs and reinsert. I have had this occur twice and reseating the bulbs took care of it.
I would rather do that in about two minutes than to schedule an appointment only to have it reoccur when I leave the dealer. |
07-21-2008, 02:23 PM | #9 | |
第一台寶馬! 爽!
29
Rep 212
Drives: 2024 X3 M40i | '08 328xi Coupe
my light goes on and off so it was hard for me to set a time to go to the dealer to have it checked out...but if yours stays out make an appointment with your dealer and get it replaced asap.
2008 E92 328xi Coupe /// Space Gray / Saddle Brown / Gray Poplar Wood / Steptronic / Premium Pkg / Navi / Sports Pkg / Heated Seats
2024 X3 M40i /// Carbon Black / Oyster / Ashwood |
07-21-2008, 02:25 PM | #10 |
97
Rep 2,188
For once I will actually provide one of the least smartass responses to a thread.
You DO need to go to the dealer. The reason is it's a "recall" (quoted because it's not TECHNICALLY a recall) for the rear bulb assemblies. I tried fixing it myself and when I wiggled the bulb it fixed the error (the same top bulb that you circled) but, it came back a week later. Just take it there and they'll fix it right. |
07-21-2008, 02:41 PM | #11 |
66
Rep 653
WALAAA! thanks, so it's a common recall problem... My break lights still works fine just the message came on... Like you guys mentioned that it would normally come on and off from time to time. Damn it! hate going to the dealer..
07-21-2008, 02:41 PM | #12 | |
66
Rep 653
07-21-2008, 02:59 PM | #13 |
210
Rep 2,110
Will I get the same malfunction after a blacklines install?
2015 335xi | Mineral Grey Metallic | Black Dakota Leather | NAV | SportLine | ZPP | ZDA | ZCW | Munich Build Retired: 2008, 2011, 2013 328xi |
07-21-2008, 03:00 PM | #14 |
Not looking 2 SPEED, just looking GOOD
45
Rep 2,516
Open it up and reinstall it, it might be a little loose. Had the same experience once. Becareful and wear rubber gloves so you don't "infect" the bulb.
07-21-2008, 04:26 PM | #15 |
15
Rep 420
This sounds like a coupe issue. You have a sedan.
1988 M5 Black/Natur (5/97-now)
2006 E90 330i Sparkling Graphite | Gray | Walnut | STEPTRONIC | ZSP | ZPP | ZCW | Navi | PDC | CA | sun shades (3/06-11/08) 2009 E90 335i Blue Water | Oyster | Walnut | STEPTRONIC | ZSP | ZPP | ZCW | Navi | PDC | CA | Logic 7 | 6FL/6NF | sun shades (12/08-now) |
07-21-2008, 04:28 PM | #16 |
15
Rep 420
Aren't these bulbs regular incandescents? Those you can touch--not that you should go out of your way to do so. The ones you need to be careful with are halogens or xenon bulbs.
07-21-2008, 04:55 PM | #18 |
14
Rep 77
The lights were functioning correctly. I had a few people check for me before I made the appointment with the dealership
Yep, SA did confirm this being a coupe only issue. |
07-21-2008, 08:11 PM | #19 |
153
Rep 5,780
Did you pop the assembly out from inside the trunk? They sometimes appear to be all lit fromt he outside but one bulb may not be. It takes less than 30 seconds to have the assembly out.
07-22-2008, 01:55 PM | #21 | |
第一台寶馬! 爽!
29
Rep 212
I guess i will make an appointment and let them know about the service bulletin: 63 02 08 SI May 2008 Rear Bulb Failure E92 Thanks guys!
