ASA AR1's and tires:
03-23-2006, 02:14 PM | #2 |
23
Rep 297
I believe all of the above statements are true, except for maybe the last one. I know some folks have 245/275 setups - but I'd prefer to play it safe, just in case...
03-23-2006, 02:16 PM | #3 | |
MAUI BUILT
485
Rep 7,781
Drives: 2006 330i MT
#2 - Yes #3 - Nope, you can go bigger without rubbing, plenty of people run 245's in front and 275's in the rear. 235 and 265 are the most accurate sizes compared to stock, so I recommend them. Danny
Arctic/Blk Leather/Alum.Trim/MT/ZSP/Sunshades/Blk Lines/M3 Illuminated Knob/Alcantara Performance Wheel/M-E-Brake Handle/Euro Fog Switch/Koni Yellows/H&R Sport Springs/19" VMR V718's w/PS2 Tires/M-Tech Body Kit/Carbon Fiber Spoiler/Bimmian Interior Bulbs/OEM Eye Glass Tray/SSK/Alcantara Boot/Split Armrest/OEM Dual Rear Power Outlets/Rear Ashtray Delete/OEM Alum. Pedals/Osram 6000K/Brex Rings/LED Side Markers/BMS Power Box
03-23-2006, 02:21 PM | #4 | |
249
Rep 484
And do they look a lot different compared to 235, 265s? |
03-23-2006, 02:23 PM | #5 | |
MAUI BUILT
485
Rep 7,781
Danny
03-23-2006, 02:25 PM | #6 | |
MAUI BUILT
485
Rep 7,781
Danny
03-23-2006, 02:42 PM | #9 | |
249
Rep 484
BTW, you owe us pictures of them on your car! |
03-23-2006, 02:49 PM | #10 | |
Black Sapphire 330i
32
Rep 362
FYI - the calculator gives you Diameter differences. Remember high school geometry taught you that Circumference = Diameter x 3.14. |
03-23-2006, 03:46 PM | #11 | |
23
Rep 297
The first XXX number, in this case 235 or 245 is the width of the tire in milimeters. There are approximately 24mm to one inch (I think). The second YY number, in this case 35 or maybe 40, is the profile of the tire. It is expressed as a percentage. In other words 235/35, means that the sidewall is 235mm x 35% = 82.25mm. 245/35 would be 85.75mm, so a difference of 3.5mm. The final RZZ number is the size of the wheel/rim in inches that the tire fits, eg. R18, R19, etc. So to summarize, the difference between 235 and 245 is as follows: - The 245 is 10mm wider - The 245 is 3.5mm taller The result of this is that with a 245 you will have marginally better handling, but your speedometer/odometer will be off by at least 2mph, maybe 3mph. You also increase weight and rolling resistance, which decreases fuel economy. The tires also look different. I personally prefer the slightly leaner look of the 235 and 265. I think that fatter tires look better on muscle cars, like mustangs, camaros, etc. My advice, stick with 235 and 265. Good luck... |
03-23-2006, 04:11 PM | #13 | |
Black Sapphire 330i
32
Rep 362
