BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    BPMSport F90 M5 Dyno
      01-30-2019, 06:00 PM   #1
BPMSport
BPMSport's Avatar
3387
Drives: Harrop M3 / F10 M5 / F82 M4
2000 BMW M5  [0.00]
1990 BMW 735i Turbo  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
We've been so slammed with projects and cars that we haven't had much time to post on here. Wanted to share a dyno of an F90 M5 we did. Before line (red) was stock, after line was with tune and downpipes. Dyno was taken in AWD mode, and 5th gear. 6th would have produced higher results. Overall very satisfied with the gains! This is also running an overly rich mixture for safety (lower 11's), so there is quite a bit of power to be gained over what is shown
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |-----
----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133----
VCP1390.00
      01-30-2019, 06:20 PM   #2
Miko M
///M
Miko M's Avatar
6651
Drives: 2020 M2C. 2020 X3M
Piggy back gives about the same gain and that's without down pipes.
Life is too short...enjoy your life
///M
      01-30-2019, 08:24 PM   #3
BPMSport
BPMSport's Avatar
3387
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
As we mentioned, this is a very conservative tune with a low 11 AFR, and is by no means a calibration intended to extract the most amount of power available. We can achieve higher than that, with no downpipes as well.
Often times calibrations are judged based on numbers alone, which is totally the wrong way to look at it. Drive-ability, safety, redundancy, are all more important than achieving a specific output gain. Piggybacks are not able to remove cold start, the top speed limiter, raise the redline, amongst other things.
Piggybacks alter and trick the control unit or associated components to output more power, they do not *properly* do it via the factory controls. There are thousands of tables in the DME that are carefully calibrated from the factory for a number of different factors, and since piggybacks alter the reality of what's occurring, these factory designed tables are not effective in the manner they were designed. Piggy backs do not have a method of directly controlling fueling, or properly suppressing errors for modified exhaust systems.
That said, there are certainly instances were piggybacks can be beneficial, such as for external controls for meth, etc. A proper flash tune is certainly the correct way of extracting additional power while maintaining all of the factory safeguards.
We'll post up a few more charts of our development F90 Comp package that has stock exhaust.
      01-30-2019, 08:34 PM   #4
brad850csi
1316
Drives: 16 F13 M6 Comp
Any chance you can overlay a stock F10 for comparison?
SCOTT26 "So as an admirer of the M5 and a potential customer of an M5 Touring. I would run naked around the streets of Garching if they were to offer one."
      01-30-2019, 08:56 PM   #5
Miko M
///M
Miko M's Avatar
6651
I know the difference in between piggy back and tune. Mine point is proper tune should bring more then double.
But I guess this is the beginning stage
///M
      01-30-2019, 09:08 PM   #6
BPMSport
BPMSport's Avatar
3387
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
This is certainly not the case. The relative difference between a piggyback and a tune is of no substance or relevance. There are limitations subject to fuel quality. You don't see 800HP Supras running 91 octane
      01-30-2019, 09:13 PM   #7
BPMSport
BPMSport's Avatar
3387
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Sure, we can do that. I put it on our to do list, will post it sometime this week
      01-30-2019, 09:54 PM   #8
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
Great and super safe numbers Mike.
Keep up the great work, look forward to your continued development of the F90!
2015 M5 - Singapore Grey Metallic - Silverstone Full Merino Interior - Executive Pack - Drivers Assist Pack -Comp Pack -
      01-31-2019, 08:48 AM   #9
Steeve19M5CP
194
Drives: 2019 MBB Blue M5 Competition
what is the max boost psi this tune is set to?
2019 F90 M5 Comp-Marina Bay Blue-B&W,HRE 21" FF04,BMC,CarbonPro wing,H&R,ZW5
2017 BMW 330i - Estoril Blue - M Sport Package
2013 Lamborghini Aventador-Pearl Green-Modified
2004 Lamborghini Gallardo-Manual 6spd -Giallo Midas Pearl Yellow-Modified
2018 Range Rover Velar S-White
      02-01-2019, 08:16 AM   #10
Lalit@autocouture
Lalit@autocouture's Avatar
374
Drives: Tributo, Superfast, M5cs
Nice!
      02-01-2019, 08:26 AM   #11
Steeve19M5CP
194
some dynojet Dyno's showed 625whp stock......was that a Dynojet rwd dyno vs awd ?
shoei7779.00
      02-01-2019, 12:32 PM   #12
shoei
7779
Drives: MW Vespa w/pink racing stripes
Not to shit on the tune's parade but you're right...
This was my stock dyno...
1. Mustang Dyno
2. AWD
3. 91 octane (yay California)
There's too many intangibles and variables but yeah...
      02-01-2019, 01:18 PM   #13
Steeve19M5CP
194
1. Mustang Dyno
2. AWD
BMS piggyback F90 m5 to compare;
      02-01-2019, 07:44 PM   #14
dmmpower
dmmpower's Avatar
No_Country
32
Drives: M5
1. Mustang Dyno
2. AWD
Not a bad value with 91 octane.
Try again with better fuel (100 or 102 octane) and you will gain 50-70 whp.
      02-01-2019, 11:41 PM   #15
shoei
7779
1. Mustang Dyno
2. AWD
Oh that's already in the game plan... Neighbor has current gen CTS-V... Get me some higher octane before we head to uhhh mexico...
He also has an alpha tuned 12c - gonna need more than bolt ons to keep up with that bish...
      02-02-2019, 10:33 AM   #16
js.chang
js.chang's Avatar
Drives: f90m5
Can I ask you ;
1) why set overly rich mixture during WOT? just for safety?
is there any claim from customer?
2) why you adapt 91 octane? is there any specific reason?
      02-02-2019, 10:49 AM   #17
r33_RGSport
r33_RGSport's Avatar
12913
Drives: G09 XM, G05 X5 40, 991.2 T
Can I ask you ;
Overly Rich is for safety measures.
They are just barely finish with this, so not too many customers running their tune on F90 M5 yet.
But seems like they have a good record around 2/3/4 series department.
He has to adapt to 91 octane since 90% of the US market for mods are in 91 octane state of California.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      02-02-2019, 11:18 AM   #18
apsuard
195
Drives: 2021 BMW M5 Competition
I had BPM stage 2 with Mike on both my F10 M5s. I was totally happy and cars were beasts. I’m sure he will fine tune it once more owners start tuning.
f90_FTW156.50
      02-02-2019, 11:37 AM   #19
r33_RGSport
12913
Oh, for sure, no doubt about it. That's why I say that this is the early stage, not finalized yet.
I would do it if I can keep my BMW longer passed the warranty period.
      02-20-2019, 02:34 PM   #20
f90_FTW
157
Drives: F90 M5
I also had stage 2 bpm sport from Mike on my f10. Was very happy with power.
I will say this though. I've already tuned my f90 once will not name, names. Didn't work out. Car didn't make any power.
I'm mentioning this because I think everybody wants to be first to market for this car, and I don't think ANYBODY has really figured it out yet.
My car is back to stock tune and I'm not even entertaining a new tune for a while.
I don't want to be people's lab rats.
The only people who have figured it out are the ones who are providing modest tunes with minimal gains.
I want a stage 2 tune, with no bugs, and I haven't found it yet. The only one close is racechip and that's a piggyback tune, and in my opinion it's modest as well. They offer 100-200km at 6.2 which is fast.. but I've already seen mid 5's and lower from the f90.
jalkster220.00
      02-20-2019, 06:35 PM   #21
TrevorM3
3322
Drives: 6.3 AMG
Smart man.
The pursuit of more power on this platform within it's infancy stages will end up costing some folks some money when things go wrong. Wait on it.
      02-21-2019, 01:17 AM   #22
BPMSport
BPMSport's Avatar
3387
2000 BMW M5  [0.00]
2008 BMW M3  [7.50]
2015 BMW M3  [0.00]
2015 BMW M5  [0.00]
Thanks everyone for the replies! We have been inundated with projects lately, but will post a lengthy reply to all of the posts/request by this weekend.
I can certainly assure everyone that all software we deliver is ready for market and we do not use customer vehicles as test subjects unless they request something out of the ordinary and are specially understand that they will be receiving development software. We have tuned many F90, comp and non comp, in many countries around the world, as well as the United States of course, without any issues to date.
f90_FTW, shot you a PM, you've got my curiosity now
Search this Thread:
Advanced Search
m5post
