BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Eventuri Intake BMW F90 M5
      01-29-2019, 09:14 AM   #1
Imran@Evolve
Imran@Evolve's Avatar
5364
Drives: All of them
BIMMERPOST
     Featured on BIMMERPOST.com
The F90 M5 Eventuri intake system was developed through extensive real world testing and airflow simulation analysis. It demonstrates the perfect balance between allowing for unrestricted airflow with our semi-open filter housings whilst maintaining low IATs through cold air saturation with our scoop and shield combination. The large front air scoops transfer ambient air directly into the intake area thus ensuring the engine doesn’t suffer from heat soak. In addition, the gold heat-reflective lined shields have integrated flow guides which direct the ambient air from the scoops into the filters. They have also managed to increase the inlet tube cross-sectional area by over 30% compared to the stock intake as it feeds through the openings in the strut braces. This allows the turbos to work more with less restriction and reduce the waste-gate duty cycles.
The Eventuri Difference
The F90 M5 Eventuri system uses their Patented Carbon Fibre Housings and Gen 2 bespoke filters, which provide an aerodynamically efficient airflow path from the filter to the turbos. Not just another cone filter with a heat shield but a unique design which invokes the Venturi affect and maintains laminar flow conditions to reduce the drag on the turbo. You can read more about the housing design and how it works here.
Product details
The Eventuri F90 M5 intake system consists of a number of components engineered to perform a specific purpose and fabricated to the highest of standards. Here are the details for each component and the design ethos behind them:
Each intake system consists of:
2 x Carbon Fiber Venturi Housings with Integrated Tubes
2 x Bespoke High Flow Generation 2 Filters
2 x Aluminium Inlet Cowls
2 x Carbon Fiber Air Scoops
2 x Laser Cut Heat Shields lined with Gold Heat Reflective Material
2 x Laser Cut Air Ramps integrated into the Heat Shields
High Quality Silicon Couplers and OEM Spec Hose Clamps
INTAKE HOUSING ASSEMBLY
The filter housings comprise of the bespoke generation 2 filters, aluminium inlet cowls, the carbon pods and integrated tubes. The carbon pods shroud the reverse mounted filters and smoothly shape the airflow down to the stock turbo inlet tubes. This is a key feature of the intake design where we have removed the requirement for a convoluted rubber hose between the airbox and the turbo inlet tubes. The filter housings and integrated tubes extend all the way to the stock turbo tubes and are able to move as one piece with the engine through the strut braces. This removes the extra interfaces of having a separate convoluted tube which the stock system requires for flexibility as the stock airboxes are mounted to the chassis so cannot move. The result is a smoother path from the filter to the turbo inlets and therefore the turbos are able to function with less drag. The diagram below summarises the differences between the stock airbox and the Eventuri F90 filter housing.
INTERNAL VOLUME
Another key design feature of the intake housings is the internal volumes of the tubing as they pass through the strut braces. On the F90 M5, the airbox system must pass through an oval opening in the strut brace on each side before reaching the turbo inlets. They have managed to increase the internal size of our intakes at this junction which results in more available volume for the turbos to draw from and therefore less restriction. The increase in cross sectional areas between the Eventuri and the stock airbox is 31% as follows:
Internal Cross Sectional Area of intake tube at the strut brace:
Stock Airbox Tube = 6487mm²
Eventuri Intake Tube = 8497mm²
PATENTED TECHNOLOGY
The patented filter housings have a smooth reduction in cross sectional area as they shroud the filters and taper down to the tubing. This geometry invokes the Venturi effect where the airflow accelerates whilst maintaining laminar conditions. It can be thought of as a large velocity stack - below is a diagram to show the comparison between our patented design and a regular intake system. The bespoke filters aid the airflow moving through the housings and allow for an even velocity profile as the airflow exits the housings.
HEAT SHIELDS AND AIR RAMPS
The filter housings sit on top of these laser cut shields which also have a gold reflective backing to aid against radiated heat transfer. The shields attach to the chassis and also provide an enclosure for the openings of the housings to draw cool air from. This is aided by the integrated air ramps fixed to the inside of each shield. These ramps guide the air from the scoops upwards to the filters so when the car is in motion - the airflow being forced into the ducts from the front scoops is then directly pushed into the filter area displacing any engine bay heat.
FRONT SCOOPS
The final carbon components in this system are the front scoops - essential to direct ambient air to the filters.
The scoops were designed for maximum efficiency in directing the incoming air to the stock duct openings. Many aftermarket scoops have a large flat area almost perpendicular to the oncoming air - not great for channeling it into the ducts as the airflow just "hits" this flat portion and creates turbulence.
Unlike most aftermarket "scoops" the Eventuri Scoops have been designed extend from the stock duct openings all the way to the grills. In order to capture as much air as possible, the scoops are shaped to the same contours as the outsides of the grills and then smoothly channel ambient air through a continuous curve to the duct openings. CAD images to illustrate the shape:
Having an effective cold air feed to the filters is an essential part of our design. Simply having some heat shields in place is not an effective means of avoiding heated air from entering the filters unless the shields create an air tight envelope around the filters. The scoops and shields in our system combine to provide the filter openings with ambient air and maintain low intake air temperature.
Sound Clip
Eventuri BMW F90 M5 Sound
Performance
The intake was tested on the road using a Vbox unit to record the acceleration from 60-130mph . Testing was carried out on the same stretch of road - again on the same day to keep variables minimum. Results show that with just the intake added - on stock software, the acceleration times from 60-130mph reduced by 0.22 seconds which is a significant improvement at such speeds. The car was tested three times in each configuration and the best time taken for each configuration for the results below.
Acceleration results summary:
60-130mph with Stock intake = 8.48 seconds
60-130mph with Eventuri intake = 8.26 seconds
The gains are from a combination of reasons:
1) The larger inlet tube volume alows the turbos to work with less drag.
2) The Venturi housings provide a smooth transition from the filter to the intake tube keeping airflow laminar.
3) The large front scoops force ambient air into the intakes keeping the IATs low.
Installation guide:
Eventuri Install Guide F90 M5
More pictures!
Appreciate 5
Miko M6650.50
xander_g986.50
VCP1390.00
///M TOWN15930.50
      01-29-2019, 10:00 AM   #2
Miko M
///M
Miko M's Avatar
6651
Drives: 2020 M2C. 2020 X3M
Nice write up!!!
Didn't think it could save .22 sec
Did you Dyno before and after to see gains in HP?
It sounds sick, I love mine
Life is too short...enjoy your life
///M
Appreciate 3
sport6.00
M 4EVER191.00
      01-29-2019, 10:34 AM   #3
Imran@Evolve
5364
Drives: All of them
Originally Posted by Miko M View Post
Nice write up!!!
We prefer Vbox testing as you get real airflow which is not really possible to replicate on the dyno. On the dyno we coudn't keep the IAT between stock and Eventuri but on the road the Eventuri had lower IAT than stock.
Glad you are happy with it. It does look and sound awesome too.
      01-29-2019, 10:53 AM   #4
soopa
113
Drives: 2018 F90 M5
Really like the looks! Hope to have one installed soon!!!
      01-29-2019, 11:06 AM   #5
onfireX5
3618
Drives: F90M5,F85X5M
August 24 vs September 11. What was the atmospheric conditions of each test ? Density altitude ?
      01-29-2019, 11:09 AM   #6
onfireX5
3618
Also, would love to see your airflow data on a Flowbench at 10" of H20.
      01-29-2019, 11:14 AM   #7
IND-Distribution
BMW obsessed
IND-Distribution's Avatar
9571
Drives: G82 M4 / G87 M2
Installed on our F90 M5.
IND DISTRIBUTION | 866-963-4520 • INSTAGRAM • YOUTUBE • FACEBOOK • FLICKR
Appreciate 5
soopa113.00
VCP1390.00
CPTM343.50
DGM M5C176.00
      01-29-2019, 11:24 AM   #8
Imran@Evolve
5364
Drives: All of them
The tests were done on the same day as close as possible. Those dates are when the graphs are generated from Vbox Tools website not the actual date on the runs.
We would only ever test back to back so conditions are as close as possible.
onfireX53617.50
      01-29-2019, 11:57 AM   #9
Miko M
///M
Miko M's Avatar
6651
That was mine assumption...back to back testing is the only way to get accurate readings
I would also do multiple runs on each and get average to eliminate any error
///M
M 4EVER191.00
      01-29-2019, 12:00 PM   #10
Imran@Evolve
5364
Drives: All of them
Hopefully we will see more independant data as more kits get out there.
      01-29-2019, 12:17 PM   #11
shayan30
120
Drives: F90 M5
Awesome!
What the expected installation time for this?
      01-29-2019, 12:30 PM   #12
Imran@Evolve
5364
Drives: All of them
Originally Posted by shayan30 View Post
Awesome!
No more than an hour. Its simple to install
shayan30119.50
      01-29-2019, 02:00 PM   #13
shoei
7779
Drives: MW Vespa w/pink racing stripes
Nice write up!!!
I did dyno right before the install... Some time next week, I'll throw her back on the same dyno to see if there are results...
Mustang Dyno
AWD
xander_g986.50
      01-29-2019, 03:23 PM   #14
onfireX5
3618
Mustang Dyno
AWD
Killer power on a Mustang.
      01-29-2019, 05:09 PM   #15
soopa
113
Drives: 2018 F90 M5
[img]https://c2.staticflickr.com/8/7837/3...1e670c3b_b.jpg[/img]
CF porn!
Appreciate 3
      01-29-2019, 06:03 PM   #16
mike@x-ph.com
Joint Chiefs of Staff
mike@x-ph.com's Avatar
24038
Drives: 07-335/12-328/18-M4/21-M4CP
Very nice
https://x-ph.com/sale/
Phone number 702-494-9435
      01-29-2019, 06:04 PM   #17
shoei
7779
Mustang Dyno
AWD
Yeah I'm not gonna lie, was expecting far worse, lol... There's a reason people call the mustang the "heartbreak machine" lol
      01-29-2019, 09:08 PM   #18
r33_RGSport
r33_RGSport's Avatar
12906
Drives: G09 XM, G05 X5 40, 991.2 T
Awesome!
Awesome!
An hour is max. This intake design it very good and spot on.
Everything slip in like a glove.
Stupid easy installation.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
SPRING Sale!! 04/01 - 04/15 - Code: "SPRING2024"
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
Appreciate 3
Miko M6650.50
VCP1390.00
      01-30-2019, 04:14 AM   #19
Imran@Evolve
5364
Drives: All of them
Yes thats worst case. It takes our techs around 30 mins.
VCP1390.00
      01-30-2019, 07:07 AM   #20
onfireX5
3618
At 10” of H20 , the stock airbox assembly flows 445cfm with stock filters but charcoal deleted. With BMC filters it flows 492cfm. What does the Eventuri flow at 10” ?
Appreciate 4
      03-07-2019, 10:23 AM   #21
xander_g
987
Drives: G30 M550i
Looks very well made and the data looks promising as well.
      03-07-2019, 12:34 PM   #22
Brake_Late
Brake_Late's Avatar
Norway
1937
Drives: 2015 F82 M4 FIREORANGE2
Eendraght Maeckt Macht
FOF82,3pedals,MPE,CCBs,Multicams,
CarbonStrucktureAnthracite, CF_Everything
BMWPhotoVin, 01of01, GTS DCT, EPS, MDM,
CS EDC,Analog Dip ,GTS parts.
Euro Vin e30 M3, FIA cage / 14.7 p / w ratio.
Euro E30 touring G30 MSport i3s LBB X5M
3.2carrera
https://www.youtube.com/channel/UClRTsfNzuz_EjUBu59UCykA
Search this Thread:
Advanced Search
m5post
