Smallest air compressor for walnut blast?
01-26-2019, 02:29 PM | #1 |
93
Rep 541
Ok so i think i need a walnut blast. My gas mileage is tanking.
I am thinking of getting the harbor freight media blaster. Right now i have a small air compressor maybe like 3 gallons. Could i use it to walnut blast? I don’t mind having to wait for it to power up. I ask. Bc space is getting limited for me and i rarely have a need for a large air compressor. |
01-26-2019, 06:08 PM | #2 |
1044
Rep 1,667
I bought a 6 gallon based on the requirements for the media blaster. Harbor freight has a portable media blaster that needs 4 cfm at 40 psi...then I found a 6 gallon Briggs and Stratton pancake compressor that can supply 4.5 cfm at 40 psi. I haven’t tried it yet...waiting for the weather to get nicer...
Jaronbwall284.50 |
01-27-2019, 12:37 PM | #5 |
Rep 16
Bimmer_Engineer1043.50 |
01-29-2019, 12:48 AM | #6 |
1933
Rep 1,532
3 gallons will not be enough. I would just do it by hand or pay someone else for that hassle. You'll get like 10 seconds of airflow before you're out.
I used a 26 gallon compressor and it was adequate, but not with a lot of margin. There was still definitely time spent waiting for the tank to re-fill. |
Jaronbwall284.50 |
01-29-2019, 12:08 PM | #7 |
253
Rep 410
I bought this 20 Gal https://www.homedepot.com/p/Husky-20...201H/206189626
Does it take 175 psi for wallnut blasting ? No. Wallnut blasting only needs about 60–90 PSI to work effectively. So its important to have a regulator to set the amount of usable and adequate PSI. This will help the tank last longer and fill quicker instead of running at max psi. Last edited by BaaQaf; 01-29-2019 at 08:14 PM.. |
Chris@VargasTurboTech1933.00 Bimmer_Engineer1043.50 |
01-29-2019, 05:57 PM | #9 |
93
Rep 541
I've been researching the heck out of air compressors, none are going to be perfect for me now b/c I don't have 240v in the garage.
I'm thinking of these - any advice? https://www.lowes.com/pd/Kobalt-20-G...sor/1000578469 https://www.lowes.com/pd/Kobalt-QUIE...sor/1000405189 https://www.walmart.com/ip/Campbell-...essor/51495094 My other questions are:
Any other tips or pitfalls to watch out for? |
01-29-2019, 10:00 PM | #10 |
69
Rep 113
I usd a 30 gallon and it was barely enough. Did something like 3.7cfm at 90 psi. Lots of waiting for it to fill bfore the next blast.
Chris@VargasTurboTech1933.00 |
01-29-2019, 11:19 PM | #11 | |
1903
Rep 6,968
I then went an bought a DeWalt D55146 from Lowe's. Awesome, Awesome air compressor. |
01-30-2019, 06:21 AM | #12 | |
93
Rep 541
01-30-2019, 06:34 AM | #13 | ||
1903
Rep 6,968
I've used the my new Dewalt for walnut blast too. No issues what so ever. You can probably get a good deal on the Dewalt 15 gallon compressor for under $375.00 right now. I almost bought that one, but opted for the small one due to space saving. https://www.homedepot.com/p/DEWALT-1...5168/302918678 Either one, will have more them enough power to walnut blast or do a brake fluid flush via Mitivac. |
01-30-2019, 06:46 AM | #14 | |
397
Rep 433
Drives: 2008 BMW 335i sedan
https://www.e90post.com/forums/showp...&postcount=129 |
01-30-2019, 06:51 AM | #15 | |
1903
Rep 6,968
1) gallons 2) CFM - the higher the better 3) max tank pressure 4) space in your garage 5) jobs you are using It for predominantly & how often. 6) ROI & initial cost $$$$ The only job that I can think of where you would want a 30 gallon tank, 200psi tank pressure & a really high CFM would be to clear your sprinkler system lines in the fall. Even then, with a really good 30 gallon tank, it would take a long time to do this job. Honestly, You are better off just paying the local guy $60.00 to do it. He's got a huge, industrial tank in his creeper van or in the back of his pickup truck. |
01-30-2019, 07:13 AM | #16 | |
1903
Rep 6,968
Or you could price out each piece Individually and probably buy everything for around $175.00 or so which would get you the aluminum cylinder adapter in that price point. Google is your friend. |
01-30-2019, 09:23 AM | #17 |
1044
Rep 1,667
mweisdorfer1902.50 |
01-30-2019, 11:04 AM | #18 |
93
Rep 541
Ok well w/ the air compressor I probably want to buy once cry once. I don't want more than i need. Everyone says ignore PSI .. but it makes sense a 200PSI tank will last twice as long at 90 PSI than a 100PSI tank theoretically right?
As far as CFM .. I'm limited to 120v outlet, so 6CFM seems to be the max i can get, 4 seems pretty common, how big a of a difference is 4 vs 6? I have no idea... All I really care about is probably sound, and refill time, ideally i'd like a fast filling quiet air compressor. For jobs? I'm going to walnut blast, besides that MAYBE use air tools down the road when working on my car but that's it. I just really don't want to buy a compressor and realize it falls short and have to rebuy one. And at this point I don't know what I don't know. The dewalts seem very nice. |
01-30-2019, 09:43 PM | #19 | |
1903
Rep 6,968
Dewalt D55146 - $299.00 - Lowe's 5.0 SCFM at 90 PSI / 200 psi 78 dBa operational noise If you have room in your garage, and you really want more air capacity, then get the DeWalt 15 gallon at Home Depot for $349.00 Dewalt D55168 - $349.00 - Home Depot 5.4 CFM at 90 PSI / 225 psi 78 dBA operational noise The 15 gallon will run considerably longer with out having to refill. The smaller 4 gallon can can run a bit without having to fill up, but quickly recharges and can hold 90psi easily while recharging. |
01-31-2019, 07:33 AM | #20 | |
93
Rep 541
01-31-2019, 08:09 AM | #21 | ||||
1903
Rep 6,968
If you want an awesome Airtool that you would use to get suspension parts off like frozen nuts on control arms get Dewalt - DWMT70773L Just make sure you get a "QUALITY" hose & fittings. Don't skimp on those items... https://www.googleadservices.com/pag...R4Q0Qx6BAgNEAE |
