BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X2 Forum (F39) Removing Rear Center Headrest?
      01-24-2019, 07:25 AM   #1
X2 Monstah
X2 Monstah's Avatar
301
Drives: 2018 X2 XDrive 28i M Sport
Is there a trick to removing the rear center headrest? I can pull it all the way up, but it stops there. It's a bit of a distraction and I know I'll never have anyone in the rear center seat. Thanks.
Mine: 2019 Mini Cooper S / Moonwalk Grey / Black Interior
Wife's: 2018 X2 XDrive 28i / MSport X / Mediterrean Blue / Mocha Dakota Leather
Previous: 2008 E92; 2014 F30; 2016 F30 M Sport; 2011 E82 (Man I miss the 1er!)
      01-24-2019, 10:22 AM   #2
RyThatGuy27
Drives: BMW X2 MSport
I would like to know as well!!!
      01-24-2019, 07:55 PM   #3
adriang
adriang's Avatar
64
Drives: 2018 BMW X2
Perhaps this is the case?
Can you try that?
dianebrat109.50
      04-09-2019, 11:24 AM   #4
farg
60
Drives: 2018 F80 M3
I tried this and there is no button underneath the plastic trim piece. Does anyone else have any ideas, or am I missing something?
      04-09-2019, 12:38 PM   #5
billnchristy
1604
Drives: 2022 M440xi GC
I would like to know too, my x1 just pulled right out, this one wants nothing to do with that.
      04-09-2019, 02:49 PM   #6
m630
m630's Avatar
958
Drives: '22 X4M Comp / ‘22 X3 / f136
‘22 X4MC  [0.00]
Same here!! I pulled as hard as possible but ot wont move!!!!!
      04-10-2019, 05:52 PM   #7
BMWZ4
BMWZ4's Avatar
1908
Drives: '23 X1/'23 Allroad Progressiv
Not removable, same with my previous 2 X3's
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
      04-10-2019, 11:58 PM   #8
numba1er
Drives: X2
Follow the video on how to pop-out the plastic tab. Once the tab is off you will need to remove the gray clip that is holds the headrest in. When the gray clip is removed you will be able to slide the headrest out.
This was the first thing I did after I parked it in my garage.
Appreciate 2
dianebrat109.50
BMWZ41908.00
      04-14-2019, 12:50 AM   #9
redcars
101
Drives: 228xi
Yes, it's like a C clip. Get a small flat blade screwdriver. You should see the end of it if you're kneeling on the rear seat facing towards the rear. Get behind it and pull towards yourself and toward the back of the car. With little force, it will pop. I believe the pic above is from the cargo area and you're seeing the loop part of the C clip.
      04-14-2019, 09:32 AM   #10
BMWZ4
BMWZ4's Avatar
1908
Huh, did not know that. Was told years ago you couldn't remove it. Thanks for the post. Learn something new every day as they say
      04-22-2019, 09:52 AM   #11
farg
60
Drives: 2018 F80 M3
Thank you for the info about the gray clip. Finally got a chance to access my daughter's X2 and spent about two minutes getting this done.
Problem solved and rearward vision improved. Thanks again!
xbimmers
