Tirerack
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wheels and Tires Forum Sponsored by The Tire Rack > Spacer size suggestions?
      01-15-2019, 10:15 PM   #1
ducatiti
ducatiti's Avatar
235
Drives: X7
Hello. I have the style 416 wheels on my E90 325i. Wheels are 18 x 8 with offset of 34. I have 225/40/18 all the way around.
Would 12F and 20R work for my setup? Thanks in advance.
EDIT:
Some pictures with 25mm spacers on the rear. Purchasing ECS 15mm front spacers next...
EDIT: 2/4/19; INSTALLED 15mm Spacers on the front
Before:
After:
      01-16-2019, 05:25 AM   #2
Achappell8
Achappell8's Avatar
68
Drives: BMW 335xi M Sport
2011 BMW 335xi  [0.00]
I believe both should be fine. In the summer I run an 8.5et29 and 9.5et23, both of which would stick out further than the setup you are describing.
Also, FYI - willtheyfit.com is an extremely helpful resource that someone shared with me for spot checking fitment of wheels
      01-16-2019, 11:59 AM   #3
ducatiti
ducatiti's Avatar
235
Drives: X7
Thanks for your input. If I just install the rear spacers, would I still need a wheel alignment?
      01-16-2019, 06:53 PM   #4
Achappell8
Achappell8's Avatar
68
I do not believe so. Alignment would only adjust camber or toe (maybe other aspects as well) but I do not think spacers alone would change the angles of the wheel, just the track width.
      01-17-2019, 03:44 PM   #5
snedanator
97
Drives: e93 335i le mans blue
Yeah a 12mm spacer will be perfect for the front. U could go 23mm in the rear and still be fine...that's what I use with a 245. And try get the spacers that Bolt to the hub...then the wheel bolts to the spacer...if u know what i mean!
      01-21-2019, 11:10 PM   #6
ducatiti
ducatiti's Avatar
235
Drives: X7
Would it be a bad idea to get these?
https://www.amazon.com/dp/B00V5YU2CQ...v_ov_lig_dp_it
edit: Based on the pictures on the succeeding post, would it look ugly if I just installed 20mm spacers on the rear?
      01-21-2019, 11:21 PM   #7
ducatiti
ducatiti's Avatar
235
Drives: X7
Took more photos today after some polishing/waxing Here is how she sits currently...
      01-21-2019, 11:27 PM   #8
ducatiti
ducatiti's Avatar
235
Drives: X7
      01-22-2019, 12:06 PM   #9
Achappell8
Achappell8's Avatar
68
Just get your spacers from Turner. Personally, I wouldn't mess around w random brand spacers.
      01-22-2019, 03:00 PM   #10
ducatiti
ducatiti's Avatar
235
Drives: X7
ECS brand spacer any good?
      01-22-2019, 05:31 PM   #11
Achappell8
Achappell8's Avatar
68
Yes that's what I run. I believe they are technically one company now - just 2 diff brands.
      01-23-2019, 04:11 AM   #12
bluewater328
626
Drives: 2011 bluewater 328i LCI sedan
Correct!
      01-23-2019, 03:37 PM   #13
snedanator
97
Yes u will be fine just doing the rear for now and it will look so much better with the 20s 🙂. If u do eventually do the front the 12mm will be good to go also.
      01-24-2019, 11:53 AM   #14
ducatiti
ducatiti's Avatar
235
Drives: X7
Originally Posted by snedanator View Post
Yes u will be fine just doing the rear for now and it will look so much better with the 20s ��. If u do eventually do the front the 12mm will be good to go also.
Thank you sir!! Looking at my pics, it does look ugly and sunken for my rears.
Can I do 25mm without any issues? Sorry don't really have the time and resource to measure at the moment.
      01-24-2019, 04:05 PM   #15
snedanator
97
I would like to say 25mm would be ok....me personally would put them on and take the risk...they might be absolutely fine.....but it's getting close to the fender. 23mm would be a safer bet...but it's up to u.
      01-24-2019, 11:30 PM   #16
ducatiti
ducatiti's Avatar
235
Drives: X7
25 it is!!! Thank you
      01-25-2019, 12:41 AM   #17
snedanator
97
probably will be fine mate as u are not lowered....it'll defo take away the sunken look and look so much better. When u getting them? And mind get some pics up to let us see the diffrence.
      01-25-2019, 10:47 AM   #18
ducatiti
ducatiti's Avatar
235
Drives: X7
I gambled and got the Precision European Motorwerks 25mm spacer from Amazon. Good price right now @ $37.99. I think it should be OK since it's only for the rear. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Trying to decide now if I should buy the 12.5mm or 15mm ECS Spacers for the front. Small difference but you think 15mm will work?
I'm receiving the 25mm for the rears tomorrow and will definitely post pictures for ya =)
      01-25-2019, 10:56 AM   #19
bluewater328
626
I gambled and got the Precision European Motorwerks 25mm spacer from Amazon. Good price right now @ $37.99. I think it should be OK since it's only for the rear. https://www.amazon.com/gp/product/B0...UTF8&psc=1
Yes, 15mm will work for you. I have them on with Sport springs.
      01-25-2019, 10:59 AM   #20
ducatiti
ducatiti's Avatar
235
Drives: X7
Ok thanks. Just to confirm, 18 x 8, 34 ET, 225/40/18 tires.
      01-25-2019, 11:03 AM   #21
snedanator
97
So do u have 225 40 18 on 18x8 wheels running et19?
      01-25-2019, 02:20 PM   #22
snedanator
97
Any pics of the front set up Bluewater?
