CIC day night auto
01-15-2019, 07:33 PM | #1 |
Rep 16
CIC day night auto
I found a settings option in the cic that lets me choose between day, night and automatic. But however automatic doens't activate the night mode when its night and headlights are on. Has anyone an idea how to activate the auto function?
regards |
01-16-2019, 10:44 AM | #4 |
457
Rep 539
Yeah the e9x night mode on the CIC systems has to be manually switched back and forth.. it's stupid and cannot be coded to work with the auto headlights like it does on the f30
CP-E DP's / Remus Race / ETS 7" FMIC / AFE DCI / Cobb V3 / ETS CP / HKS BOV
01-17-2019, 12:31 AM | #5 | |
76
Rep 143
Drives: 2020 M340i
Or if you don't want to mess with coding you can just set the preset to go to the menu and switch between them that way.
2020 M340i | Mineral Grey Metallic | Premium | Exec | Adaptive M Suspension | Harmon/Kardon
Previous: 2011 E90 335i | Black Sapphire Metallic | 2007 E90 335i | Monaco Blue Metallic |
01-17-2019, 11:17 AM | #6 |
1208
Rep 2,835
The reason it doesn't work in the E9x cars is that the CiC CID does not have the light sensor that CCC CID does.
One way around this is to use a CiC CID out of a 5 series. It's the same as the one in the E9x CiC, but it has the light sensor (little pinhole at the bottom of the display) and clear plastic housing also. What is the setting heading that needs to be changed? Cause after I found micro fractures in my retro CID, I purchased another one and scored one with the light sensor. |
01-17-2019, 01:43 PM | #7 | ||
457
Rep 539
01-17-2019, 09:06 PM | #9 |
76
Rep 143
Drives: 2020 M340i
I think it's NAVI_MAPMODE_AUTOMATIC. Try setting that to nicht_aktiv.
01-17-2019, 10:14 PM | #10 |
Save the manuals!
6016
Rep 6,746
How? That's even more work. With the above suggestion, you are making a shortcut on the head unit's "1,2,3,4,5,6" preset buttons. Set it to one of them, and that is now your toggle for day/night mode. Literally one press after creating the preset/shortcut.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
01-18-2019, 01:02 PM | #11 | |
457
Rep 539
I have an M3 and the amount of features it has compared to a regular 3 series is quite lengthy... 3 presets alone are for driving modes, suspension settings, engine dynamics etc.
Tags |
automatic, cic, coding, day night |
