TNT Racewerks
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > BMW Coding > Coding injectors help please!
      01-15-2019, 05:55 PM   #1
patton001
Drives: 2009 BMW 335i
Hi all. I am new here but been lurking for a while. Good forum, lots of good info. Anyhow I have hit a little snag. I am going to replace my injectors this weekend because I have 3 leakers. The new ones are Index 12's.
The procedure looks pretty straight forward but I just thought I would look at the coding procedure today as a warm up for this weekend. I have a Schwaben to do the coding. I hooked it up today and drilled down to the screen with the values and instead of just seeing 6 digits to change like all of the videos have shown, under each Cylinder I had 2 matching 22 digit numbers. It looked like this:
Cylinder 1
94411625119547117501497
Each cylinder was like this (different number of course). Has anyone run into this before? I have no idea what values to use now for the new injectors.
Any help would be appreciated.
Thanks
      01-22-2019, 03:29 PM   #2
rediahad
17
Drives: E71, E93, E92
I just did this a couple weeks ago with ntsc expert. Way easier, i dont remember running into any numbers like that just coded in the two sets of 3 digit numbers that came on each injecter
      01-23-2019, 07:06 AM   #3
n2siast
76
Drives: E93 335i M-SPORT
If you have access to INPA, I'd suggest using that as it is quick and easy. Literally 2 minutes and you're done.
