2Addicts
2Addicts
2Addicts | BMW 2-Series forum BMW 2 Series (F22) Forum 2 Series Active Tourer Discussions Install Amplifier in F46 Gran Tourer
      01-14-2019, 10:26 PM   #1
MinhPT
Drives: 218i
I do not know if my F46 Gran Tourer 2016 has amplifier, does anyone know how to check if BMW has amplifier?
My F46 has 6 speakers: 4 in four door and 2 bass under front seat, these speaker may connect to NBT and powered by NBT.
I had replaced 4 door speakers, now I wish to upgrade the amplifier and the bass drivers.
How can I start?
      07-19-2020, 04:22 AM   #2
benjanos
Drives: F45
This web site is very helpful https://www.newtis.info/tisv2/a/en/
You can see when the amplifier would be installed by clicking here https://www.newtis.info/tisv2/a/en/f...nit/1VnYWEpyPn
You can have an explanation of the various Audi Systems here
https://www.newtis.info/tisv2/a/en/f...system/X0Ni0ZY
Hope it helps!
      07-29-2020, 07:03 AM   #3
mrashton
45
Drives: 2017 G32 6GT; 2014 F45 218i
How can I start?
If you don't have the dash centre speaker then you only have the base audio system where the speakers are powered by the headunit and not a separate amplifier. Do a VIN decode on MDECODER.COM andlook for the upgraded Audio options 676 or 677 which do have a separate amplifier.
      08-10-2021, 11:23 PM   #4
mst_lv
Drives: BMW F46, VOLVO C70
Does anybody know the differences between the HiFi and Harman Kardon amp in the F46? I have the 676 Hifi with the amp, but I'll be upgrading all the speakers from HK, as the HiFi is kind of rubbish. Can I leave the original amp or better to swap that out too?
      08-19-2021, 10:46 PM   #5
Mogki
Mogki's Avatar
34
Drives: BMW 230XI
In the F22 you can swap the speakers and it will help slightly but the best bang for the buck in one go is getting a HK amp or 3rd party, that being said no you don't need it, you may need some Y splitter cables for the door mirror mounted tweeters assuming its the same as the F22
      10-05-2021, 01:54 AM   #6
Gordian76
Drives: BMW 218i GT
can anybody advise me is the F46 able to use the Most25 for Audio?
      10-05-2021, 01:59 AM   #7
Gordian76
Drives: BMW 218i GT
I have done splitting the fiber optic cable from the HU to a MOST Decoder and connect to my Alpine DSP.
The strange thing is, the warrning chimes and reverse beep are playing through my speakers but not the audio/music. I can bluetooth to my DSP and successfully play songs thru my setup.
I am beginning to suspect is the HU cable to route the audio thru the MOST25 network? or is it a coding issue?
Can anybody advise?
2addicts
