01-10-2019, 10:21 AM | #1 |
49
Rep 201
Cracked stock rim, looking for options
Hi all,
One of my tires was slowly letting out pressure the past few days, so today I went to a mechanic who took the wheel off the car and found that there's a hairline crack on the inside of the wheel which is causing the issue. Wanted to get your advice on options: 1) I hear that some wheels can be welded, not sure if this is safe or worth it or what the cost would be. Thoughts? It's a lease, so even if I weld, will I need to replace the wheel when I turn the car in after another 16 months? 2) I've seen remanufactured or used wheels (OEM originals) on eBay from reputable sellers for about $250 to $300 (style 634). Anyone recommend just buying something that is crack free and inspected, having it put on, and balanced (total cost would be in the $400 - $500 range). 3) I put in an inquiry at the dealer to see the cost of a new wheel and for them to put it on. Not sure how much this would be, any thoughts? I'm guessing at least another couple hundred bucks more than the used/remanufactured route, but any experience would help. Appreciate any ideas or thoughts on the above. The car has about 22,000 miles, will be turned in after about 16 months, its a 2017 530i xDrive and the runflat tire on the wheel appeared fine when inspected (at least for now, hopefully doesn't get damaged in the couple days I have while I figure out replacement). Thanks! |
01-24-2019, 06:45 PM | #2 |
2110
Rep 34,199
Hey,
I've had a couple guys from the forum reach out to me and tell me they cracked/bent their OEM wheels. Most of the guys went for a stronger more durable aftermarket wheel and have has 0 issues. I would look into some aftermarket wheels as an option. PM me if you have any questions!
Have questions? Contact us below bmw@vibemotorsports.com. 800-814-8423 Ext 107 Ask for Tom https://www.vibemotorsports.com/wheels |
09-21-2020, 09:31 PM | #3 | |
55
Rep 196
07-13-2021, 10:58 PM | #4 | ||
Rep 31
Drives: 2022 BMW 750i xDrive
